Trunk wont pop up on its own anymore..... Common??
Old Nov 18, 2012 | 08:44 PM
daboss085's Avatar
Default Trunk wont pop up on its own anymore..... Common??
hey guys, my trunk release will only pop up once in a while on its own. I notice that when I pop it more often, that it will release up on its own, but if it has been a couple days then it seems like it gets stuck and I have to force it up.... any ideas? is this common?
Old Nov 18, 2012 | 09:45 PM
GaryinOregon's Avatar
Mine does the same. It seems like I have to clean it and put some lotion on it to keep the trunk rubber seal soft and non sticky. Otherwise, it does this. That's what Iv'e seemed to notice.
Old Nov 18, 2012 | 10:50 PM
QuartzSTypeR's Avatar
Mine is the same way. Some days its fine, others it needs some help.
Old Nov 19, 2012 | 10:12 AM
kr98664's Avatar
Ditto here. Seems to be a common problem. I believe the compression of the seal is the main force that pops the lid open when the latch is actuated. I replaced the seal last year due to a leak, and then for a few months the trunk popped open reliably every time. Now that the new seal has taken a set, the release operation is back to hit or miss.
Old Nov 19, 2012 | 10:17 AM
jimgoose's Avatar
Mine does that too. Just needs a little lift to "help" it up about a third of the time, I should say. It needs a little wallop to close it properly too, but nothing too annoying - I'm used to it.
Old Nov 19, 2012 | 09:52 PM
Diamondrmp's Avatar
I'm glad mine doesn't do that all the time. I really hate how the trunk flies open.
Old Nov 20, 2012 | 08:17 AM
JagV8's Avatar
If it opens too fast I expect you could reposition the springs.
Old Nov 22, 2012 | 11:52 PM
Diamondrmp's Avatar
there is no spring its a strut.
Old Nov 23, 2012 | 09:04 PM
clubairth1's Avatar
Community Influencer
I looked at my 2005 STR and its springs damped by a strut. Maybe that was a option?
Old Nov 24, 2012 | 02:30 AM
JagV8's Avatar
Mine too. Look more closely?
Old Nov 25, 2012 | 11:57 AM
Diamondrmp's Avatar
I looked closer and saw the spring
Old Nov 25, 2012 | 12:14 PM
Diamondrmp's Avatar
there are three holes to hook the spring too. Mine is hooked in the hole closest to the rear of the car. Once I figure out how to SAFELY move the spring I will try the other 2 holes to see how they work
garycs
Nov 24, 2017 01:36 PM
Col. Sandurz
Sep 28, 2015 12:49 PM
bydand
Sep 27, 2015 01:18 PM
ssshield
Sep 24, 2015 08:29 PM
drewlabarbera
Sep 22, 2015 01:54 AM
