When should a motor oil 'drain plug' be replaced?
Old Feb 8, 2015 | 11:38 AM
BKSinAZ's Avatar
Default When should a motor oil 'drain plug' be replaced?
I am sorry if this is a stupid question and I feel bad for asking....
Currently doing my annual motor oil change and realize that I have not replaced the drain plug in a few years. Should this be done? Most cars have a removable gasket on the drain plugs and it is just the gasket that needs to be replaced with each oil change, but my Jaguar drain plug does not appear to have a gasket that can be replaced.
One last question about this drain plug.... is it a 10mm?
2005 S-Type V6 (Not the "R')
Old Feb 8, 2015 | 11:46 AM
Gippsland's Avatar
They are so cheap I just order one with the filters. Any other car I have owned a sump plug is for life,but Jaguar being Jaguar....
Old Feb 8, 2015 | 11:54 AM
BKSinAZ's Avatar
Jag charges $20 for a drain plug.... not cheap in my opinion. I am not aware if Autozone or Checker sells them for a Jag. I guess I can call.
But back to my question, how often does the drain plug need to be replaced? I realize a gasket that slides onto a drain plug should be replaced each time an oil change is done. But the 2005 S-type V6 oil drain plug does not have a removable gasket.
Old Feb 8, 2015 | 12:03 PM
I've never changed mine since 2007 when I got the car, no problems so far.
Old Feb 8, 2015 | 12:08 PM
BKSinAZ's Avatar
Do you know what size socket size it takes to remove the original drain plug?
Old Feb 8, 2015 | 12:18 PM
Jon89's Avatar
My 2005 S-Type's oil pan drain plug is 13mm. I replaced it a couple of years ago because the head is relatively soft metal and mine was becoming rounded after years of oil & filter changes. With the new plug I quit using my socket wrench to remove and install it and switched to my open-ended box wrench instead. Better overall fit, no tool wobble, therefore much less likely to round off the head....
My oil pan drain plug indeed has a replaceable rubber seal. The local Jaguar dealership parts department gave me two or three of them back in March 2009 when I was purchasing another part. The rubber seal's part number is NCE1850AB. I've never opened the original sealed plastic packaging in an effort to preserve them in case I ever need them....
Old Feb 8, 2015 | 12:24 PM
BKSinAZ's Avatar
Sounds like I might be missing a gasket.
Old Feb 8, 2015 | 09:04 PM
Dennis Catone's Avatar
I just had the oil changed by a garage that services Jaguars and they replaced the Drain Plug Seal for $3.72 and it was labeled as a Jaguar part
Old Feb 9, 2015 | 07:34 PM
BKSinAZ's Avatar
Default 2005 S-Type V6.... where is motor oil drain plug.
I think I found it, but before I loosen the bolt, does anyone have a picture of the location?
Please.
Old Feb 9, 2015 | 08:13 PM
joycesjag's Avatar
Here ya' go:
Attached Thumbnails When should a motor oil 'drain plug' be replaced?-alt.-bolts-edit-.jpg
Old Feb 10, 2015 | 06:06 PM
car5car's Avatar
If you know plug diameter, you can buy a seal washer from any auto parts store.
Old Mar 3, 2015 | 07:56 PM
Sonspit's Avatar
Yup just changed my oil and purchased 3 new gaskets for about 4.00... Just told them make model and year.
Old Mar 4, 2015 | 08:58 AM
tbird6's Avatar
My STR has an O-ring on the drain plug not a gasket. Still on the original plug and O-ring at 111K miles.
Old Mar 4, 2015 | 10:48 AM
Now you are going to sell it some poor unsuspecting soul!
Old Mar 5, 2015 | 12:49 PM
tbird6's Avatar
True enough! But it has chrome wheels. Does that help?
Old Mar 9, 2015 | 04:09 PM
Sonspit's Avatar
Smile
Yeah That's what I meant.. o ring..
xjrjag
Nov 27, 2025 09:16 AM
DavidNagel
Dec 29, 2017 09:16 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
hawianjim
Aug 29, 2015 07:23 PM
