Where to look for engine numbers
Subscribe
Aug 17, 2010 | 12:52 PM
I've run a thread search on where to find engine numbers, but came up empty. Can anyone tell me where to look for the AJ-V8 engine number ?
Thanks in advance
Reply 0
Aug 17, 2010 | 01:39 PM
The "cheat" way is ask a dealer, although that doesn't guarantee your engine is still the one they have on their database.
The location is described (badly?) in this https://www.jaguarforums.com/forum/a...achmentid=2914
Reply 0
Aug 17, 2010 | 02:35 PM
Here is a picture of what you are looking for. It will be tough to see with the engine in the car. It's on the left side of the engine block and almost directly behind the engine mount. Look for the big screw in freeze plug. I think it will be dirty so cleaning and a strong light "might" let you read it. Do you have a borescope by chance??
Where to look for engine numbers-4.2l-sc-long-block-serial-number-stamping.jpg
Reply 0
Aug 17, 2010 | 03:08 PM
So THAT's what I couldn't find!! No wonder. Thanks!
(just my curiousity - I couldn't follow the pesky jtis/etc stuff)
Reply 0
Aug 17, 2010 | 07:18 PM
Quote: Here is a picture of what you are looking for. It will be tough to see with the engine in the car. It's on the left side of the engine block and almost directly behind the engine mount. Look for the big screw in freeze plug. I think it will be dirty so cleaning and a strong light "might" let you read it. Do you have a borescope by chance??
Unfortunately no, I don't have a bore scope.
Reply 1
Aug 17, 2010 | 07:21 PM
Quote: Unfortunately no, I don't have a bore scope.
@clubairth1- I'll take a look.
Reply 0
Aug 17, 2010 | 08:54 PM
Let us know if it's possible to read this with the engine in the car. It would be interesting!
Reply 0
Aug 20, 2010 | 04:08 PM
Most of the numbers on the side of the block are the alpha/numeric coding for the piston/cylinder and crank bearing/journal sizing info. The serial number (manufacture time/date) is at the front 'B'bank side of the thermostat housing mount hole on many engines. Jaguar JEPC lists the number at the rear of the 'B'bank cylinder head on the bell housing casting area but all the engines I have are not numbered there. Check both places for your engine number.
This engine pictured was made 1997 Nov 19 at 08:39
971119 0839
bob gauff
Reply 0
Aug 21, 2010 | 09:35 AM
Incorrect. Here is where the JTIS says to find the engine number. Remember this is for the S Type. Might be different for other models.
Automatic Transmission Number;The serial number of the transmission unit is displayed on a metal label or bar code (where equipped) attached to the transmission casing.
Engine Number (V6);The engine number is contained on a bar code label on the front cover and is also stamped in the cylinder block casting on the left hand side of the engine below the engine mounting.
Engine Number (V8);The serial number is stamped on an engine web on the left hand side of the cylinder block behind the engine mounting. The emission code is also located here, on the transmission flange.
Reply 0
Aug 21, 2010 | 10:07 AM
Do you reckon those are the same places as in the Vehicle Specifications?
Here https://www.jaguarforums.com/forum/a...achmentid=2914
Reply 0
Aug 21, 2010 | 10:33 AM
Jagv8:
Thanks for that document! I did not have a copy before you posted it. It only talks about the VIN which is on a sticker in the drivers door jam among other places. I could not find anything about where to look for the engine serial number?
Reply 0
Aug 21, 2010 | 11:34 AM
Aargh! Sorry, I thought it was in there but it isn't!
(It's a handy PDF, though.)
Reply 0
Aug 21, 2010 | 01:49 PM
I have to be honest, I didn't look for the engine no. on the car. I took JagV8's advice and e-mailed jaguarpartscenter.com and asked them if they could find out what my engine no. is and they e-mailed it back to me from the Jaguar data bank.
Reply 0
Aug 21, 2010 | 02:02 PM
That's good to know! But I have ask; Why do you need this number? I usually supply the last 6 digits of the VIN to identify the car?
Reply 0
Aug 22, 2010 | 11:41 AM
Quote: That's good to know! But I have ask; Why do you need this number? I usually supply the last 6 digits of the VIN to identify the car?
There are a number of engine parts that require you to know in which series of
engine numbers your engine is located
Reply 0
Subscribe
Currently Active Users (1)
