I have taken the manifolds off to change plugs and coils and bought the pcv valve as long as I had it down. Can't find where it goes and hate to put everything back without replacing it. No posts as to where it really is and all anybody does is talk about it. No pictures. Someone has to know! HELP!!
There is an OIL/VAPOR separator on the top of the block that can ONLY be replaced by removing one or both cylinder heads!!
The rubber 'elbow' hose should be replaced as it is easy to get to with the intake components removed.
There is also an improved breather elbow at the top of the system that has probably already been replaced by now.
The crank case breather system has no replaceable 'valve' as such.
What is the part number that you bought to install?
I just found my 2000MY S-Type powertrain introduction student guide (JJM101517-92) and sure enough on page 16 there is a description of the spring loaded PCV valve.!!
There is another confusion regarding PCV valves. The ones for 2000 models are situated above the rubber elbow but this part is no longer available.
They try to sell you the ones for the 2002+ models but it is a different design.
