Will a 2002 V8 seat fit into a 2004 str?
Old Jun 2, 2025 | 08:49 PM
Beretta9's Avatar
Default Will a 2002 V8 seat fit into a 2004 str?
Not seen anyone else mention how much more comfortable the 1st gen seats are compared to 2nd and 3rd gen s type seats. Looking at picking up an str for cheap but really not a fan of the seats.
Old Jun 3, 2025 | 01:56 AM
JagV8's Avatar
The STR tended (by default?) to be fitted with a kind of racing seat but the other kind could (probably?) be fitted.
I suspect one's rear shape/size is largely what makes one or the other more comfy...
Whether the early kind would fit... probably. Might lose some functionality.
Old Jun 3, 2025 | 02:44 AM
Beretta9's Avatar
For me it’s the bottom cushion. Seems like they made the seat thinner in every way to allow more leg room for all passengers. I’m comparing to an 03 though but assume the 04 str will be just as thin. I might try swapping the 02 with the 03 seat one day to find out.
Old Jun 3, 2025 | 08:21 PM
scottjh9's Avatar
I think the bolt pattern would be the same, but it would be the wire connections because the STR had 16 way power seats on both sides. I don't know about the standard V8.
Old Jun 6, 2025 | 10:46 PM
xalty's Avatar
seat controller is totally different. look at the wiring diagrams and you’ll probably be able to hack up the internal seat harness enough to make it work. should just be 2 wires to each of the 4 motors for basic control
Old Jun 10, 2025 | 05:17 AM
M-e-l-l-o-w's Avatar
I think there may also be issues with the occupancy sensor in the seats.
From what I read some years ago now these are set to the control unit at the factory and can not be re-set even using IDS (or SDD) but I have not tried this myself so this may be wrong?
elDariusVargas
Dec 28, 2023 03:39 PM
kiloslanga
Aug 19, 2023 04:47 PM
Mithrilweaver
May 27, 2021 10:02 AM
macc2t
19
Mar 14, 2011 12:36 PM
Mcavty
Aug 4, 2010 05:27 AM
