Wiring in the trunk and front bumper
Old Mar 6, 2021 | 01:09 PM
e_brugal's Avatar
Default Wiring in the trunk and front bumper
Hi guys, last week i took out the spare tire and was cleaning the trunk of the car and notice this cable just beside the battery, search to see from where it was but couln't find where to connect.
The other cable is in the front bumper, was checking the righ hand fog light that is loose and found it. Is in front of the radiator, the cable isn't long enough to get to the fog light. i know that my father change the headlights feom Halogen to Xenon bulbs, don't know if this cable and socket is from the old connection of one of the headlights
Does anyone knows what this two sockets are for and where does they go?
Thanks for any help
Old Mar 6, 2021 | 06:49 PM
kr98664's Avatar
The connector in the trunk was for the transit isolation relay. This device was removed before delivery to the customer. The harness was no longer needed and tucked out of way.
No idea about the connector up front.
Old Mar 7, 2021 | 04:57 PM
davidladewig's Avatar
There is a side light just above the fog light. Turn on your parking lights and see if one of them is not on. It is the yellow one. There is also the yellow turn signal side light on the back side of the fender. Turn on your turn signal and it should flash.
Old Mar 7, 2021 | 06:34 PM
e_brugal's Avatar
Thanks!!!
The wiring is not long enough to get there. But I will check tomorrow
Thanks!!
Old Mar 8, 2021 | 11:20 AM
Aarcuda's Avatar
Tell us the wire colors w stripe colors. Then search the electrical schematics
Old Mar 8, 2021 | 11:49 AM
JagV8's Avatar
There are multiple unused connectors, scattered around the car. Normal for S-Types.
Old Mar 9, 2021 | 06:46 AM
e_brugal's Avatar
Thanks for any help
Was searching on ebay for a fuel level arm (finally found and bought one last week and seller backed up ​​​​​​) and saw this fuel injector S824 harness connector pigtail that is identical to the one I haven hanging in the front of the car. Link to the one I saw on ebay
https://www.ebay.com/itm/FUEL-INJECTOR-s824-HARNESS-CONNECTOR-PIGTAIL-FITS-JEEP-DODGE-FORD-HYUNDAI-MAZDA/163220836270?fits=Year%3A2001%7CModel%3AS-Type%7CMake%3AJaguar&hash=item2600b84fae:g:~ZQAAOS wPJxbgZrw​​​
Other one specify that is ABS/ fuel injector harness conector
https://www.ebay.com/itm/ABS-Fuel-Injector-Harness-Connector-Pigtail-S824-S-824-1P1344-WPT-1051-PT2160/173451338737?fits=Year%3A2001%7CModel%3AS-Type%7CMake%3AJaguar&epid=3022169691&hash=item2862 8163f1:g:E5sAAOSwUv5bZjN8
Does this need to be connected? Sorry for the question but not a mechanic, learning in a way with you guys
Old Mar 7, 2025 | 10:58 AM
e_brugal's Avatar
Hi, won't open another threat for this as this wire is also in the trunk.
I will assume that this wire and conector is for the amplifier. I don't know what happened that the mechanic that worked with the ECM disconnect this when hi was searching for the problem when the car didn't start before realising that the problem was the ECM.
yesterday i got in the trunk of the car to take a look of another thing and find this two connector disconnected, i thought, well, this should be connected, and did it, immediately it started to make a bussing noise like the muffler had a hole (the car was on), i disconnect it and the noise stopped.
any idea of what's happening?
are this really the Amplifier connectors?
Any help will be apreciated
Old Mar 17, 2025 | 07:05 PM
e_brugal's Avatar
Hi, no one can guide me with this one?
Why every time i connect it start making that sound?
MarioBrragan
Apr 11, 2020 08:11 PM
mcamp
Nov 25, 2018 10:53 AM
Spikepaga
Oct 8, 2016 01:16 PM
SilverXKR
Feb 17, 2014 11:37 AM
blaydes99
May 24, 2012 05:39 PM
