Would like to know 2000 S-Type 3.0
Old Apr 12, 2010 | 10:29 AM
Gus's Avatar
Gus
Default Would like to know 2000 S-Type 3.0
I am looking at a 2000 s-type 3.0? What is it that I should be looking for (problems)?
Old Apr 13, 2010 | 08:01 PM
Gus's Avatar
Gus
I am now a proud owner of a 2000 S-Type 3.0. I will be selling my 95 xj6 4.0 that was in “The Essential Buyers Guide” page 11 by Peter Crespin and keeping our 99 xk8. I have read several posts and other than the typical Jaguar problems Trans, Coil packs, A/C, window regulator and head lights I am unaware of other issues. I had replaced both the front and rear window regulators and polished the headlights back to life. I had the transmission cable adjusted and replaced the plugs, 2 coil packs, brakes front and rear. If you can put me in the right direction for additional opportunities I would greatly appreciate it.
Old Apr 13, 2010 | 09:07 PM
chucky60's Avatar
Default ?
You may have just about everything that has been listed. Wipers have had a few problem if not used enough.Enjoy!
Old Apr 14, 2010 | 07:23 AM
Gus's Avatar
Gus
Thank You! I will look into the wipers and see if I have a potential problem. I will be working on it for the next few weeks and will see what I got.
Old Apr 14, 2010 | 08:26 AM
VMV's Avatar
VMV
Gus,
Watch your coolant expansion tank for leakage, valve cover gasket oil leaks and suspension bushings. It seems like you have everything covered pretty well so far. I have a 2000 3.0 SE and its been a great car for the past 10 years.
best wishes VMV
Old Apr 14, 2010 | 08:55 AM
Gus's Avatar
Gus
Good to know! Thank You!
Old Apr 14, 2010 | 09:41 AM
Jon89's Avatar
The early S-Types are prone to water leaks at the trunk seals, and sometimes at the taillight cluster seals. So check your seals and keep them pliable with a rub-on product such as Sil-Glyde....
Old Apr 14, 2010 | 11:03 AM
Gus's Avatar
Gus
Thank You!
Old Sep 15, 2010 | 05:38 PM
shawnethan's Avatar
I have an Expansion tank leak how do I get to it to replace?
bdboyle
Sep 16, 2019 05:58 PM
Poet
Oct 2, 2015 09:00 AM
Rocky15
Sep 28, 2015 04:59 PM
Rocky15
Sep 26, 2015 07:40 AM
zdrapec
Sep 25, 2015 05:49 AM
