Remote unlock
Old 10-16-2018, 08:28 AM
gmarand11's Avatar
Default Remote unlock
I have a 2015 F Type. When it is sitting out on a rainy day the fob will not unlock the door. No problem after a car wash. The dealer could not find a problem but I suspect it is a sensor . Needless to say that trying to open the door with the key when it is raining is an aggravation plus this sets off the alarm as well. Any help would be appreciated
Old 10-16-2018, 08:36 AM
Unhingd's Avatar
Received 4,637 Likes on 3,359 Posts
Do you not have passive unlock? Is it possible that your remote is getting wet when raining?
Old 10-16-2018, 08:47 AM
DJS's Avatar
DJS
DJS is online now
Received 2,067 Likes on 1,372 Posts
Perhaps the fob battery is getting weak? I had to replace mine this spring.
Old 10-16-2018, 09:19 AM
scm's Avatar
scm
scm is offline
Received 1,384 Likes on 1,051 Posts
Does it happen with both fobs (assuming you have two)? If not, then I'd second the battery suggestion.
Old 10-16-2018, 09:22 AM
gmarand11's Avatar
Happens with both fobs and the other one is rarely used
Old 10-16-2018, 09:55 AM
DJS's Avatar
DJS
DJS is online now
Here are the antenna locations for the fob in the convertible. If you have a coupe, should be listed in the maintenance section of your manual. Don't know if this of help, but maybe try cleaning around #2 & #4 if they're excessively dirty?
Old 10-16-2018, 10:05 AM
gmarand11's Avatar
Awesome. Will try it today. Thnx
Old 10-16-2018, 02:46 PM
gmarand11's Avatar
DJS-no luck.
Unhnged- what do you mean by 'passive unlock'?
Old 10-16-2018, 02:53 PM
DJS's Avatar
DJS
DJS is online now
Can you walk around the car, to see if it will unlock from a specific location/direction?
Wonder if Unhingd is referring to keyless entry? Push a little button on the door handle, and it unlocks and the handle pops out, assuming the key fob is within range.
Old 10-16-2018, 03:54 PM
gmarand11's Avatar
Just tried the keyless entry as described in the manual. Did not open the door. Does not allow the door to lock when closed either. May be on to something here
Old 10-16-2018, 03:57 PM
gmarand11's Avatar
BTW I tried different locations and distances and works fine. Only happens when the car sits in the rain.
Old 10-16-2018, 05:48 PM
RGPV6S's Avatar
If you haven't done so already change the batteries in the fobs. The batteries in both fobs for my 2014 died within a few days of each other and one was never used. The spare one died a few days after I started using it because the first one died.
Old 10-16-2018, 07:58 PM
gmarand11's Avatar
Worth a try since it is easy and cheap. Waiting for rain to try these suggestions. Thanks all
msobug
01-19-2024 07:17 AM
Mish_Mish
03-29-2011 09:50 AM
Timxxl
11-12-2010 10:16 AM
Greg561
05-09-2009 06:22 PM
siegelj
06-17-2007 03:49 PM
Quick Reply: Remote unlock
