F-Type R AWD Transfer Case Fluid Change DIY
Old Dec 24, 2020 | 12:02 PM
Therock88's Avatar
Default F-Type R AWD Transfer Case Fluid Change DIY
Hi Group...
Since I just finished the Transmission Fluid and Transfer Case Fluid Service, and it was still fresh in my mind, I went ahead and put the process in my DIY Template/Format. I was able to re-use many steps from the transmission service, so that was helpful.
I used a couple of tips and pictures from Rondog on this Forum - So Thanks Rondog!
The process can be performed in at least two different approaches, one removing the cross member for access and one without. Each has pros and cons, so pick what works best for you...I tried to document both approaches and referenced steps by using an A or B through the document.
So, if anyone is looking to DIY your Transfer Case Fluid Service, I hope this will help you out. Always check your specific model and specs, and make sure you use the correct parts for YOUR vehicle. Note you only need a 1 Liter bottle of fluid for this.
Enjoy the DIY, and good luck if you try it.
DC
LINK TO MY DIY HERE
Old Dec 24, 2020 | 04:40 PM
DJS's Avatar
DJS
You forgot option 3: transmission fluid change party at your house, everyone’s invited!
Thanks for this. Hoping to build a barn (with lift) next year so I can do some of this stuff myself in the future.
Old Dec 24, 2020 | 04:44 PM
Therock88's Avatar
Haha! Yep...Bring them on over, and let's start tearing them up! (That would be Option C by the way)
Good luck with your Barn and Lift set-up...That would be great!
Take care,
DC
Old Dec 25, 2020 | 08:20 AM
Unhingd's Avatar
Dave,
Maybe next year when you have the lift, you can host the New England DYI F-Type Run. We could do oil changes, pulley installs (only lower), heat-x and intake upgrades, exhaust mods, etc. Only half kidding.
Old Dec 25, 2020 | 08:35 AM
scm's Avatar
scm
Was I the only one to read that as "hoist the New England DYI f-Type Run"?
Old Dec 25, 2020 | 12:14 PM
DJS's Avatar
DJS
Yes.
Next year is likely optimistic. Just bought the land, but have to deal with zoning and all that jazz. But I could see hosting part of the 2022 Double-Secret Probation and Fluid Change Tour.
Old Dec 25, 2020 | 03:58 PM
Unhingd's Avatar
Yes.
Old Feb 9, 2023 | 06:42 PM
Therock88's Avatar
Looks like my original link broke.
THIS ONE SHOULD WORK.
DC
Old Mar 11, 2024 | 02:20 PM
BigJay13's Avatar
ROCK88, Do you still have the DIY you did for the Transmission and the Transfer case flush? For some reason I can't get to them. Thank you
Old Mar 11, 2024 | 04:56 PM
ThunderKitty's Avatar
Most of the time a 'group fluid change' would sound really bad, but with context- a great idea!
Old Mar 24, 2024 | 12:46 PM
Trainingdragon's Avatar
Hello everyone,
I'm new hear so forgive me if I'm not current in all the good info that has been shared. I found this thread and these in general are so very helpful. I have a 16 F-Type R. What a beast. About 41k miles. I hear that low speed clunk everyone talks about. I'm way out of the original warranty and CPO warranty. I picked up the car used at about 25k miles several years ago. I want to change the Rear Diff fluid, front diff fluid and Transfer case fluid. Rear diff I'm good with and have all the info I need. I'm having trouble locking down which fluid to use for the front and transfer case. When I researched the fluid noted on the bulletins associated with this thread, it seems that maybe those fluids are no longer available? Can you anyone advise on a brand, type, and possible place to buy for the front and transfer case. Thanks and my apologies if this has been covered many times on other threads.
Thanks friends
Old Nov 24, 2025 | 01:30 PM
Joons's Avatar
Link to your DIY doesn't work for me. Has it moved?
Old Nov 24, 2025 | 02:22 PM
Robtrt8's Avatar
See post #8
Old Yesterday | 11:16 PM
SilverFoxSix's Avatar
Default Bolts spin....
DC
the two bolts on the driver's side of the mid support brace (the one under the transfer case and part of the transmission ) came out about 1/8th of an inch and just spin.... how are they attached up inside there? What is going on?
Therock88
Jan 15, 2024 01:55 AM
TM1238
Aug 5, 2020 07:15 AM
Rigsby94
Feb 11, 2013 09:56 AM
MattSteele
Oct 14, 2010 11:20 PM
Dragonsse
Jul 20, 2008 08:25 PM
