"gearbox failure"
Old Sep 8, 2007 | 10:06 AM
ArdenX's Avatar
Default RE: "gearbox failure"
This happened to me in an old auto X-Type. Turned out to be a big problem and they ended up replacing the entire transmission under warranty after only one flash of the Gearbox Fault light. Get it checked out ASAP.
Old Sep 8, 2007 | 04:45 PM
ArdenX's Avatar
They replaced because the Gearbox Fault light was triggered. I don't know exactly what triggered the light. My VIN was flagged by Jaguar so they gave me a replacement transmission. When I brought in the car I didn't think that the simple light was a big deal as it had shut back off but apparently there were some serious problems worthy of a replacement transmission.
Old Sep 9, 2007 | 05:28 PM
Hey Joey, take Arden's advice and get it to the dealer to check ASAP.........Is it under warranty?
Jim
Old Sep 10, 2007 | 03:31 AM
Cadillac's Avatar
They do use Tech II device and it should exactly tell about your tranny culprit .However if it's an intermittent problem it is one of the hardest things to diagnose .
Hope things will be ok
Old Sep 10, 2007 | 07:22 AM
SpartanX's Avatar
Man Auto X-Type Trannies are a problematic unit. I remember reading up on the X before I bought it and I told my fiance she'll have to learn how to drive the 5MT because I wasn't buying the auto with all the horror stories I've read online.
Hope everything is fine with your car. I've had to get a tranny for a car before. NOT FUN at all.
Old Sep 11, 2007 | 08:00 PM
hankycbr's Avatar
I had a similar problem the other day. my jag went into limp mode and I could barely get to the side of the road. My accelerator pedal had no effect. gearbox failure, engine failure, dsc failure, kept flashing in sequence. I tried several times turning off the engine and starting again. My power finally came back but the check engine light was lit and happened once more on the way to the shop. Believe Me, i was thinking the worst after reading some of the horror stories on this forum. I obviously don't have a warranty. My mechanic ran the codes and found out that the air sensor by the air filter was faulty. He replaced the sensor today and no problems so far after 60 miles. I still have my fingers crossed. Anyone else have a similar problem?
I hope this helps!
DevonDavid
Aug 4, 2016 07:43 PM
floz
Aug 4, 2015 08:38 AM
jaguarfanman
Jul 26, 2015 03:38 AM
04JagXtype
Mar 15, 2013 11:15 AM
Mar 18, 2010 04:41 PM
