02 x type wont start...NEED HELP!!!
Old Nov 28, 2009 | 10:35 AM
teamswooop16's Avatar
Default 02 x type wont start...NEED HELP!!!
so in short the jag sat for about a year and when i went to turn it over the
battery was dead so i had AAA replace it. the car will turn over but it is
getting no fuel (will run with starting fluid) i checked the fuel pump fuse and the fuel switch...
ne ideas will be very helpful, im thinking maybe the fuel pump got clogged with dirt or? thanks guys
Old Nov 28, 2009 | 01:32 PM
Thermo's Avatar
Veteran: Navy
Team, first start with the obvious, replace the fuel filter. Secondly, get the car up on jackstands on the driver's side. You want to be able to put your head near the gas tank. Now, have someone turn the key to the "RUN" position (do not go all the way to the "START" position). You should hear the fuel pump run for about 5 seconds. If you don't hear anything, then that would tell me you have a bad fuel pump or the fuel pump is not getting any power. Unfortunately, the control module for the fuel pump is located on top of the fuel tank, so, what that means for you is that you have to drop the fuel tank to do any sort of troubleshooting. Dropping the fuel tank is a little bit of a bugger because of how it is mounted, especially if there is some gas in it.
If you want to tackle a project, you can drop the fuel tank and before hand, let me know and I will tell you which wires you need to check to prove parts good and parts bad.
Old Nov 28, 2009 | 01:56 PM
thanks man already bought the filter and going to change it today...will let you know if
i get lucky lol im trying to fix this car for a roomate and im use too a little s2000
Old Nov 28, 2009 | 08:46 PM
lol so this car has 160,000 miles and that was the stock filter, it was clogged pretty bad but after all that still no start. fuel was in the lines and you can hear the pump turn on but no pressure...so pump is done right?
p.s if u have a diagram on how to replace it would be very helpful, dont know if im going to attempt it but just want to take a look
Old Nov 28, 2009 | 09:56 PM
Thermo's Avatar
Veteran: Navy
Team, before we go swapping stuff out, what I want you to do is to get into the car and look at the instrument cluster. Now, insert the key and and hold it in the "START" position for about 10 seconds. For the first 3, the security light will be lit. After three seconds, does the security light remain lit? IF so, the computer lost your programming and you need to have the keys reprogrammed to your car. That should allow the car to start.
If this doesn't fix your car, then I will give you the step by step instructions out of the JTIS CD. That will tell you everything that you need to do to get access for what you want to do.
Old Nov 29, 2009 | 12:53 PM
i checked today and the light turns off (red light next to e brake)
Old Nov 29, 2009 | 06:19 PM
Thermo's Avatar
Veteran: Navy
Team, well, then it is looking like we are getting ready to drop the tank. We have pretty much ruled everything else out. If you have any questions about this, let me know and we will get you hooked up.
Old Nov 29, 2009 | 07:38 PM
thanks...this forum has been a huge help. is their ne special tips that i need to know? or is it just like ne other fuel pump replacement?
way2far
Aug 31, 2022 09:26 AM
ZJag
26
Sep 5, 2016 03:33 PM
KarimPA
Sep 12, 2015 08:15 AM
raffoulig
Sep 8, 2015 01:56 AM
KarimPA
Sep 3, 2015 07:32 PM
