'03 P0174 When Cold
Old Jan 4, 2018 | 10:36 AM
patsanger's Avatar
Default '03 P0174 When Cold
Lately it has been near or below freezing and I've been getting a lot of P0174 codes. I've looked and don't see anything - is there something that could be shrinking in the cold or any ideas?
Thanks!
Pat
Old Jan 4, 2018 | 10:53 AM
Bud Tender's Avatar
https://www.jaguarforums.com/forum/x...-codes-185098/
Old Jan 4, 2018 | 11:05 AM
patsanger's Avatar
Thanks - I have looked at this and nothing seems to be wrong - the engine breather hose is in good shape and has the ribs, the brake booster is older but seems solid still, and the tuning valve seals are green...
I was just curious about the fact that it is throwing this in cold weather... in case there was some suggestions to check anything else...
Thanks!
Old Jan 4, 2018 | 01:26 PM
avern1's Avatar
If you are sure you don't get the code when the weather is warmer, I would look at the upper and lower intake manifold seals. You are probably looking for a rubber seal that is shrinking and leaking when cold.
There is an o-ring seal in the brake booster line at the intake manifold that can get hard and shrink
I would advise you to get the short and long term fuel trims recorded. Once we see how bad the leak is we might be able to pin point a better diagnosis.
Old Jan 4, 2018 | 01:39 PM
Alfadude's Avatar
You could also check the accoridan hose between teh MAF and the throttle body to make sure it doesn't have a small crack or that iot is tight.
Old Jan 5, 2018 | 12:02 PM
patsanger's Avatar
Thanks for the suggestions - I'm wondering about the accordian hose as it looks like the prior owner uses zipties to secure it... hmm...
Here's the code info after driving it around for about 20 minutes (I thought that was best - if you need cold readings let me know)
P0174 codes 1/2
P0174 codes 2/2
Old Jan 5, 2018 | 01:11 PM
Alfadude's Avatar
Uhhhhhhhh.......zip ties? I think that would be a logical place to start.
Old Jan 6, 2018 | 04:21 AM
JagV8's Avatar
Even a tiny leak would need fixing. Zip ties suggest a major leak
tnord
Oct 10, 2014 04:10 PM
tnord
Oct 7, 2014 12:34 PM
chater210
Feb 12, 2014 11:44 AM
jaguars4r
Aug 8, 2012 10:40 PM
onca
Sep 22, 2010 09:50 AM
