04 Xtype 3.0 recent check engine and limp mode
Old May 24, 2009 | 09:07 AM
pcglobal's Avatar
Smile 04 Xtype 3.0 recent check engine and limp mode
Hello All!
I'm glad I've found this forum. Anyway, I had my oil changed to synthetic and recently in the morning, a little red gear appears on the dash, I think this is the "check engine light"? Or is it the transmission? I bought the car used and of course no owners manual to read....
The car stays in the RPM range of about 3000 and the car has no power. I turn the car off for about 20 seconds and restart and no more problems until the car sits for over 8 hours then I have to go through the process all over again.
I also used a lower octane fuel for the past 2 tankfulls. I used the mid grade just to try and save a few bucks.
I guess the question, is i the synthetic oil, the lower octane gas, or a whole different problem? I havent had any problems since I bought the car a year ago.
It has 64,000 miles on it. And it has the automatic tranny (I think they all do)
Any help would be greatly appreciated.
Old May 24, 2009 | 09:50 AM
christo's Avatar
If you search the forums there is lots of info on this issue.
In the FAQ's there is this...
https://www.jaguarforums.com/forum/s...ead.php?t=9913
Probably has noothing to do with the oil or gas, how ever I would not cheap out on the gas. You will benefit from it in the long run - besides, I get 2 extra miles to the gallon on premium. Less fillups in the long run, do why not right?
Old May 24, 2009 | 01:21 PM
pcglobal's Avatar
Default Looked at old postings
My situation seems different.
Anyway, I took the car to Autozone, they checked for codes however, there weren't any error codes coming up.
I don't quite get this. Anyway, the engine light has not come back on. I also added some octane boost to the previous gas and will try to use only Premium to see if that helps.
I also gave a listen to the engine at idle and there is no air leaks or sounds out of the ordinary that I could tell of.
I have read of many different issues from throttle body, leaking hoses etc. Has anyone else experienced my same situation ?
Thanks!
Old May 24, 2009 | 02:24 PM
Disco stu55's Avatar
thats interesting, never heard of a issue like that before
Old May 24, 2009 | 02:44 PM
pcglobal's Avatar
Default great....a mysterious problem
Of course I end with a mystery issue. I wonder if it is because of all the rain in S. Fla. maybe something got wet inside causing intermittent problems?
I will keep the forum posted on this.
Old May 25, 2009 | 08:57 AM
christo's Avatar
I sent you pm with some stuff that might help - also is an owners manual.
Do you think maybe you over filled the car with oil? This could have fouled the plugs?
Old May 26, 2009 | 01:24 PM
pcglobal's Avatar
Default Update:
It was the powertrain light that came on, not the engine. It has not come on since. I went to Autozone to see what codes would come up and nothing came up! Zero. I thought this was a indicator malfunction with the exception each time the light came on (2 times) the car went into Limp home mode until I turned the car off, waited about 20 seconds and turned back on without a problem.
Therefore, if this happens again, I will assume its a computer issue or transmission problem. However the car has been shifting perfect since I got it.
I will keep y'all posted.
Old May 26, 2009 | 06:02 PM
starvinmarvin08's Avatar
I had a similar issue, it reset and was fine after a restart. Not sure what is going on there.
Old Dec 8, 2009 | 04:41 PM
melworks's Avatar
Had the same problem. Now they are replacing my throttle body.
Old Nov 23, 2012 | 08:39 PM
lou228's Avatar
Default powertrain malfunction light on
every now and then this red light comes on as well as check engine light also i shut it off i turn it back on and drive fine for a while. i got it scaned a pedal sensor came up i put that in and still having this problem any advice anyone this car is driving me crazy
philwarner
Dec 6, 2021 07:13 AM
Isoruku
Jun 19, 2020 12:54 PM
Steve Langridge
Sep 3, 2015 07:35 PM
johanasu
Sep 3, 2015 12:39 PM
lee,lee
Aug 31, 2015 04:35 PM
