05 X-type intermittent not turning over
Old Oct 22, 2015 | 11:30 AM
Carlyt88's Avatar
Default 05 X-type intermittent not turning over
Hi, I have a 2005 x type estate which intermittently will not start. I put the key in and it tries to turn over bit won't start so I then turn engine off n start again at which point I then get nothing, no turning over, no clicking just nothin but all the lights on the dash and radio come on. I had the aa out who ran their diagnostics and p0070 air temp maintenance and p1000 old system faults came upset he said that shunt stop it from starting like it was. Anyway once he had run diagnostics even tho he didn't do anything with them the car started straight away. Any suggestions would be great as I have no idea! Thank you!
Old Oct 22, 2015 | 07:20 PM
avern1's Avatar
Just a stab in the dark but it sounds like bad/lose/dirty battery connections.
Old Oct 23, 2015 | 10:14 AM
Carlyt88's Avatar
Thanks,I'll get it checked. Not sure if it's relevant but when it won't start the red light come on the temp gauge and stays on even though the car is cold and the gauge doesn't move?
Old Oct 23, 2015 | 01:44 PM
avern1's Avatar
Weak batteries and bad connections will make the instrument cluster on a Jag light up like a Christmas tree. Let's see if it is connections or your battery. Get them cleaned and tightened then have the battery load tested.
The battery can have enough juice to turn the engine over but not enough that the ecm will allow fuel and starting.
Old Oct 24, 2015 | 11:27 AM
Carlyt88's Avatar
So checked all that and it's still doing it :-( the immobiliser light behind the gear stick stays on whenever it doesn't start, cud it be the immobiliser?
Old Oct 24, 2015 | 12:09 PM
avern1's Avatar
It is very possible. Do you know where it is located? If you do push down on the button on the top to reset it. If that lets it start, we will have to figure out the next steps.
Old Oct 24, 2015 | 12:17 PM
Carlyt88's Avatar
There's an immobiliser button? All I can see is the light that on the middle console directly behind the gear stick, next to a button that looks like traction control.
Old Oct 24, 2015 | 04:28 PM
Carlyt88's Avatar
Found this thread, sounds exactly like my car so gunna get this checked, something about broken/corroded wires under radiator
http://www.jaguarforum.com/showthread.php?t=39497
Old Oct 24, 2015 | 06:04 PM
avern1's Avatar
Looks like a reasonable pursuit. You might also try swapping out relay 12 in the engine fuse box. It is the relay for the starter.
Old Oct 25, 2015 | 07:15 PM
billbjork's Avatar
you COULD be having a issue with the security system.( Turn the key NOTHING, off and on with the ignition key and it starts) is what usually happens. Some times the door lock system or the ignition key does this. Open and close ,lock/unlock ALL doors, same with hood, trunk and try a different key see if it helps
rominempire
28
Oct 8, 2020 10:39 AM
Marka
22
Sep 11, 2016 12:09 AM
Msteiner
May 16, 2016 12:19 AM
HuncaMunca
Sep 27, 2015 02:47 PM
puddled
Sep 24, 2015 01:09 PM
