2002 / 03 x-type phone question
Old Jul 16, 2009 | 02:04 PM
x-typeandbeyond's Avatar
Default 2002 / 03 x-type phone question
Hi everyone i just picked up my new car a early 2003 x-type
the car has the nav system fitted which has the phone button
how or is it possible to connect a phone wired or bluetooth
Old Jul 17, 2009 | 05:23 PM
aladamson's Avatar
This may sound obvious, but is there a phone handset in the top part of the arm rest? It would seem a little funny to have button there that has no purpose.
I've got nav and phone in my 03 - rather than look into bluetooth conversion, i've put in a prepaid sim. If you've got it the phone system is very well integrated - a very user friendly, classy addition
Old Jul 18, 2009 | 12:01 AM
wolv2401's Avatar
i dont think i have the phone system installed in my navi system, but is there a way to add it? I only have the button on the radio, but when I push that button it just says "their is no phone fitted" or something like that.
Old Jul 18, 2009 | 12:55 PM
MeeMo's Avatar
dude some of the models has bluetooth i guess 04 & up but try searching for new devices in your phone if you find the name jaguar connect to it and the pin # is 1313 for most jaguars
i hope this helps
Old Jul 18, 2009 | 02:48 PM
wolv2401's Avatar
ya i tried with my old phone, i will try with my new one. but i honestly don't think i have that feature equipped. i dont have that button they were talkin about by the armrest, at least that I can see. I will call the Jag Tech support or a dealership to ask them too. They should be able to tell from my VIN number or somethin.
Thanks.
Old Jul 18, 2009 | 11:46 PM
ajl1212's Avatar
Bluetooth is available on certain '03 models (VIN specific) and newer models. It does, however, need to be installed from the dealer (or I suppose you could do it yourself if your handy enough) and I believe you need to have the microphone installed. From what I hear, it's close to $2,000 to have it done.
If you can find it, I would recommend looking at the X-Type accessories brochure. I tried to find it on Jaguar's North American website but I couldn't. The brochure should give you the VINs that the bluetooth is compatable with.
With the bluetooth installed, you can use the phone buttons and keypad on the steering wheel/radio to make calls from selected bluetooth phones. Some phones will also allow the transfer on the phone's phonebook to the cars radio / nav display. Again, the brochure will give you more information. Hope this helps...
Old Jul 18, 2009 | 11:51 PM
queenmb's Avatar
All X Types have the phone button whether the car is equipped with the phone feature or not.
Old Jul 18, 2009 | 11:57 PM
ajl1212's Avatar
This link may be useful:
http://bluetooth.jaguarusa.com/dial....&lang=american
Old Jul 19, 2009 | 12:35 PM
Disco stu55's Avatar
BIG HELP, thanks aj
Old Jul 20, 2009 | 09:59 AM
wolv2401's Avatar
So if I enter in my VIN, and then a new menu pops up asking for my phone info, that means my car is equipped with the phone system? Or is that just a walkthrough on how to snyc up the phone.
Old Jul 20, 2009 | 12:04 PM
millergd's Avatar
Thumbs down
If the Jaguar bluetooth system (for which barely any 2003's are compatible) for the X-Type is as bad as the factory S-Type system, my advice is save your money and buy a $50 Plantronics earpiece instead. (That translates to being only 40 times cheaper than the Jaguar system!)
The BT on my 2006 S-Type R is pathetic. The RF mixer performance is horrible, leaving the listener on the other end with a dominant humming sound, and your voice as a faint echo in the background. In short, it has the audio quality of a 10 year old's Playskool walkie talkie. And for $2k, that's waayyyy overpriced. I don't use it for business or personal calls as nobody -- landline or cellphone -- can ever hear through the humming noise.
BT on the new XF's is supposed to be awesome, though.
--Geoff
03 X-Type Sport 2.5 148k km
06 S-Type R 49k mi (non-Sport edition)
Old Jul 20, 2009 | 04:59 PM
wolv2401's Avatar
Well, ya, mine does not have it then. When I hit the phone button on the NAVI unit, it jus says that "This system is not phone fitted". I take that as it don't have it installed. I just got a little excited that it might already be in it. I wouldn't consider paying even $500 for that system, let alone $2000. I will just use my bluetooth as always if it comes down to it.
Thanks!!!
Old Jul 20, 2009 | 07:00 PM
ajl1212's Avatar
I believe if you enter your VIN it tells you whether your car is compatible with the Jaguar Bluetooth System. When you enter your phone info, it tells you whether or the phone is compatible and if so, which features are enabled. I haven't tried this personally, as the '02 X-Type I'm looking to buy I know for a fact is not compatible with the Bluetooth system. Hope that helps. Good luck.
Old Jul 21, 2009 | 02:12 AM
wolv2401's Avatar
so you have already entered your VIN on that website and it says the vehicle is not compatible? If so that means that my vehicle might have it after all, I just am not setting it up correctly. The instructions just all say to enter in like ##3.... but i don't see any keys at all.
Anyways, I will look into this more when I get back from my work trip this week.
Thanks!!
Old Jul 21, 2009 | 01:56 PM
ajl1212's Avatar
I didn't bother entering my VIN because Bluetooth for the X-Types is only available on select '03 models and '04-newer. If I get an '02, there's no point in checking.
I did find the X-Type's accessories brochure which gives you the VINs that are compatible with the Bluetooth system for the X-Type.
"Available on 2003 Model Year and up X-TYPEs from VIN D31148 onward, except VIN range E373149-E46479 due to omission of voice pre-wire."
- Jag X-Type accessories brochure.
Note, if your VIN is compatible, it does not mean your car already has the Bluetooth installed. It simply means that it is prewired to have the Bluetooth system installed. The phone buttons are on all X-Types, regardless if it has Bluetooth/is compatible with Bluetooth or has the hard wired phone offered in older Jags. As I said before, I hear it's about $2,000 to have the Bluetooth installed. However, it would allow you to dial calls straight from your radio/nav screen and allow the transfer of your cell's phonebook (certain phones). In addition, it would display signal strength, batter life, etc.
Here is the link for the brochure. I'm sure this will help out anyone looking to install Bluetooth on their X-Type. It should also give a starting point on which questions to ask your dealer if you plan on having the dealer install it.
http://www.kigjamaica.com/assets/pdf...x-type2007.pdf
Hope this helps everyone. Good luck
Old Jul 21, 2009 | 03:25 PM
boobea's Avatar
Default phone question
Sorry to tell you this, but the 03 system is no longer useable. I have a '03, My 03 was delivered with nav, phone, and voice. When the US went to the analog phone system, the phone and bluetooth integrated with the nav were rendered useless. I use a bluetooth on the visor, and the old system for a phone book. Hope this helps... Don
Old May 26, 2016 | 07:55 AM
julian g's Avatar
i hope this helps
Hey man...i have an 03 xtype, ghetto no nav screen and just a button with a phone on it. is that like bluetooth? does it pair with smartphones?
Steviedee1st
Nov 28, 2023 06:32 PM
way2far
Aug 31, 2022 09:26 AM
cissdm
May 3, 2016 06:02 AM
the whittys
Sep 15, 2015 01:47 AM
DatDude
Sep 8, 2015 11:36 PM
