2002 X-Type no air volume on defrost
Old Feb 16, 2013 | 04:32 PM
krash's Avatar
Default 2002 X-Type no air volume on defrost
I have done the repair to the air bypass door to fix my fogging problem but I am not getting much volume out of the defrost. All other air vent selections give good air volume. I replaced the pollen filter as well but no luck. I looked at all the acctuators under the glove box side and all appear to turn with different selections to console, so doesn't seem to be electrical or a bad acctuator. Could the door inside the console be stuck or broke? If so how do I access it to check or fix?
Old Feb 16, 2013 | 04:33 PM
krash's Avatar
I have a 2002 X-type 3.0
Old Feb 16, 2013 | 06:00 PM
Jac's Avatar
Jac
Try pulling your cabin filter back out and make sure you blend door is open a little. If not, put something in there like a pencil to keep it open a little bit.
Old Feb 16, 2013 | 06:07 PM
krash's Avatar
Thanks. Just fixed the blend door by gluing the acctuator arm in, so that issue is resolved. But I still do not have much air volume out of the defrost.
Steviedee1st
Nov 28, 2023 06:32 PM
way2far
Aug 31, 2022 09:26 AM
cissdm
May 3, 2016 06:02 AM
the whittys
Sep 15, 2015 01:47 AM
avern1
Sep 6, 2015 04:22 PM
