75W140 Gear Oil (T-Case vs Diff)
Old Apr 23, 2013 | 02:29 PM
rclangelan's Avatar
Default 75W140 Gear Oil (T-Case vs Diff)
Just hit 25,000 miles in my 2003 2.5. I bought myself some 75W140 synthetic gear (Royal Purple) to do a T-Case drain/fill. Is this the same stuff I will want to use in my rear diff?
Thanks.
Old Apr 23, 2013 | 03:02 PM
daxter1987's Avatar
I don't like royal purple. I personally like Motul or Red Line:
Link:
Motul Gear 300 75W90
Old Apr 23, 2013 | 03:05 PM
daxter1987's Avatar
Sorry forgot to answer your question, the specification for your car according to alldata is
M2C 192A Synthetic
which is the same for both the transfer case and the diff.
Best of luck!
Old Apr 23, 2013 | 03:23 PM
rclangelan's Avatar
Went to Advanced Auto to pick up the oil. Royal Purple is all they had in stock. $20 a quart! Damn!
Thanks for the input.
Old Apr 23, 2013 | 05:31 PM
dennis black's Avatar
20 Year Member
i use redline ...but royal purple is fine
Old Apr 23, 2013 | 05:51 PM
UntouchablesInc's Avatar
Is there a reason why you don't like Royal Purple?
Old Apr 23, 2013 | 06:33 PM
Yaguareté's Avatar
The only oils I would put in my Jag for any part but especially the transfer case are Redline, AMSoil and Motul.
I personally have AMSoil now
You'll be fine with the Royal Purple but there have been negative remarks on the fillers/additives they use.
Old Apr 25, 2013 | 07:34 AM
daxter1987's Avatar
My reasons are:
_Royal purple is not a synthetic by european definition, and Jags are made in europe.
_Motul, Red Line, and Amsoil (forgot about this one I like them too), and Total are excelent ester based synthetics when you compare the specifications (flash point for example)
_As far as I know. ester based synthetics are better...
But my experience comes a lot from seeing these oils perform in engines and transmissions, I've never seen a difference in a differential oil change.
And as a mechanic, I congratulate you in being so meticulous in the maintenance of your car, I can honestly say I don't see a lot of people like you.
daxter1987's Avatar
Sorry forgot to point out that Amsoil is not ester based
bamforp
Aug 14, 2024 05:36 PM
tomsjag
Jun 10, 2023 10:02 AM
RaceDiagnostics
Jul 7, 2022 06:41 AM
Jandreu
Jun 30, 2022 03:10 PM
AtholC
Sep 9, 2015 09:07 PM
