air bag light
Old Oct 22, 2013 | 11:45 AM
dontag's Avatar
Default air bag light
Just recently bought a 2005 x-type jaguar and the air bag light is on
I was told the problem is the clock switch.
Will the air bags still work if this is the problem
How hard is it to replace and where can I find a replacement part
Old Oct 22, 2013 | 12:41 PM
Welcome to the forum dontag,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Oct 26, 2013 | 05:10 AM
j.g.sibson's Avatar
Hi Dontag, I have the same problem with my 2007 X-Type on occasions,did you manage to find a solution?
When I took this up with my local Jaguarship in Queensland,they said it was because my wife was too light and she should put some weight on!They said it isn't detecting anyone in the front seat! I thought,what sort of fool do they think I am?
Anyway,it still happens on irregular moments but I would be interested if you've found a solution.
Regards John
Old Oct 26, 2013 | 10:41 PM
dontag's Avatar
The dealer told me it was the clock spring.
Waiting on the part to see if that solves the problem
Old Oct 27, 2013 | 07:40 AM
I can sympathise with anyone having Airbag issues. It took me six months to troubleshoot mine!
( https://www.jaguarforums.com/forum/x...de-17-a-94959/ )
The SRS (Supplementary Restraint System) has become ever more complex on all Jaguar models almost to the point of needing dealer level diagnostics to be able to repair it. Here's the schematic of the components in your X-Type:
As you can see there's a lot of sensors which can trigger the dash Airbag warning light or the PAD Passenger Air Bag Deactivation) indicator.
The first thing to check is 'normal' behaviour. The SRS completes a self check when the ignition is switched on:
1. Turn the ignition switch to the ON position
2. Observe the airbag warning light function
3. Warning light ON solid for six seconds
4. Warning light goes off and stays off
If there's a fault on the system, the following occurs:
3, Warning light ON solid for six seconds
4. Warning light goes off for two seconds
5. Warning light flashes the appropriate number of times for the fault logged
6. Warning light goes off for two seconds
7. The sequence is repeated five times
8. Warning light stays ON until the ignition is switched OFF
The flashes in (5) may appear random but they are showing Flash (sometimes known as Blink) Codes which gives information on the fault.
For example, my issue was Flash Code 17 shown as lamp ON for one occurence of 0.5 seconds, then lamp OFF for one second, followed by seven occurences of lamp flashing ON/OFF for 0.5 seconds each. This indicated Code (1 - 7) 17.
If your vehicle is displaying a Flash Code, it could help determine the cause of the fault.
Old Oct 28, 2013 | 08:07 AM
jonesy1974xtype's Avatar
Just a thought.
Is it the airbag light on the passenger side?
The passenger side airbag in the dash automatically turns off if there is a small person sat on the seat (or luggage of similar weight) in order to avoid injury. The airbag lamp in the same then illuminates.
Cheers,
Jonesy
Old Oct 28, 2013 | 11:45 PM
dontag's Avatar
I air bag light is giving the same flash code 1-7 (17)
What did not replace to fix the problem?
Old Oct 28, 2013 | 11:48 PM
dontag's Avatar
Try this again - it is late so the typing has gone the way of my eye sight.
My air bag light is giving the same flash code 1-7 (17)
What did you replace to fix the problem
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
redrover41
23
Sep 25, 2015 01:33 PM
OkieTim
Sep 2, 2015 12:48 PM
