Alternator R&R 2003 xtype 2.5l - RESOLVED
Old Sep 5, 2013 | 08:50 PM
bal150's Avatar
Default Alternator R&R 2003 xtype 2.5l - RESOLVED
Hey guys I have the car on the lift right now and im not sure the best way to get the alternator out any suggestions would be great looked through here and cant seem to find complete instruction thanks !
Last edited by GGG; Sep 9, 2013 at 07:56 AM. Reason: Add 'RESOLVED' to thread title
Old Sep 6, 2013 | 05:32 AM
Welcome to the forum bal150,
I've moved your question from General Tech Help section to X-Type section for advice from members with the same model as you have.
JTIS (Jaguar technical Information System) gives first removing the A/C Compressor as part of the procedure! The guys here must have found a way round that.
Old Sep 6, 2013 | 06:13 AM
Stuart Beattie's Avatar
https://www.jaguarforums.com/forum/x...replace-34499/
Hi Bal150, I hope this helps you?
And a big welcome to the forum, the guys and gals are sure to help you out as they have done for myself! It may be a good idea to thank those who point you in the right direction too! Thermo has a few post in this thread you can click on!
Good luck Chum! Stu
Old Sep 6, 2013 | 06:22 AM
This may be more useful, Regards, Stu
Old Sep 6, 2013 | 08:34 AM
Replacing the alternator in an X-Type
Hi Bal150, this is the guide I stole from the jag co uk website, hope it helps?
Best Regards, Stu
Old Sep 6, 2013 | 04:30 PM
Danny A Fish's Avatar
I read and reread that thread (how to change the alternator from above without removing ac compressor) and nearly attempted the job but the bit about flexing the radiator fan housing just drained my already modest reservoir of courage so I coughed up 2.5hrs labour at the local mechanic to do the job and got the ac system recharged while I (they) were at it.
Of note, this my second replacement alternator. I,m fairly sure the first had a limited life because the cables were bad but were not replaced. Not sure but either way, they are a known weak link in the electrical system when they age so you may want to consider new ones. I replaced them myself this time and hopefully this alternator will. Last more than 2 years.
Good. Luck! Post how you go.
Old Sep 6, 2013 | 06:46 PM
The shortcut method of removal from above is covered in post #5. For comparison and completeness, here's the JTIS procedure:
1. AC Compressor Removal & Refit:
JTIS - X TYPE AC Compressor.pdf
2. Alternator Removal & Refit:
JTIS - X TYPE Alternator.pdf
It sounds like they started with the alternator and built the car round it. What a pain to replace!
Old Sep 7, 2013 | 07:37 PM
bal150's Avatar
Default Follow up on the alternator r&r
I would first like to say thank you to everyone who responded to my distress call!!I had to remove the air box ,serp belt,compressor,then alternator,also replaced the cables,and the plastic thermostat pipe. it was very brittle.Iwas going to go the fan route but not much room to get it out didn't want to break anything.the whole job took me about three hours and I repair cars for a living,just never had to do one of these,thanks again guys!!
Old Sep 7, 2013 | 07:40 PM
bal150's Avatar
thank you!!
Old Sep 9, 2013 | 07:55 AM
No worries Bal150,
I've found it's a huge strain on certain replacements and getting space you have to be a magician!
You did it though so well done to you! It's worth it when you get to the other side.
And I hope your baby is serving you well too!!
Regards, Stu
Old Sep 9, 2013 | 07:56 AM
Good to hear you got the job done.
Thanks for posting the method you chose and the result.
I've added 'RESOLVED' to your thread title to help anyone searching for this information in future.
Old Sep 9, 2013 | 07:35 PM
Thanks for the update. You have made me feel not so bad about chickening out of the "flex and jimmy the radiator fan housing out of the car" method!!
MrWhite
19
Jun 14, 2022 07:49 PM
JimC64
31
May 30, 2016 03:04 PM
3jagfamily
Oct 1, 2015 01:49 AM
BlakeConverse
Sep 28, 2015 02:22 PM
SoCalJagS
Sep 27, 2015 09:20 AM
