blinking check engine light
Old Nov 29, 2015 | 01:16 PM
Illu187's Avatar
Default blinking check engine light
hello I bought a 2002 Jaguar Xtype. it drove good home the after a few days i got a blinking check engine light with the codes P0300, p0301, p0303, p0305, p1313/p1316. I changed the IMT o-rings for both valves and it is still acting up with these codes.
Old Nov 29, 2015 | 05:16 PM
Thermo's Avatar
Veteran: Navy
If the chech engine light is blinking, that is saying that conditions are such that further operation of the engine may cause component damage. Based on the codes that you are getting, i would be looking at either the coils or the plugs. ghat would be the most likely. Granted, is your pcv hose smooth or ribbed (if you look at it and are not sure, then it is smooth). If it is smooth, check the under side for a split in the hose. After that, check the brake booster line for cracks in the check valve (bulge in the center if the line).
That should cover most of the likely causes.
Old Nov 30, 2015 | 02:10 AM
JagV8's Avatar
Flashing MIL = catalyst damage occurring at that time.
Try not to drive it at all until fixed.
Old Nov 30, 2015 | 07:52 AM
Revere's Avatar
Adding to what Thermo said, while checking the plugs look for oil. If you find any then you need to replace the valve cover gaskets.
Old Dec 6, 2015 | 04:56 PM
Illu187's Avatar
i changed the coils and plugs on all 6. now i am getting p300, p1316. and it still blinks but it comes then goes away
Old Dec 7, 2015 | 01:48 AM
JagV8's Avatar
What do fuel trims show? Any signs of an air leak?
Old Dec 7, 2015 | 09:30 AM
Illu187's Avatar
i checked the fuel trim. At idel the Short Term on Banks 1 and 2 is at 0 the Long Term for Banks 1 and 2 is at -0.8. When driving i saw it at Short Term Bank 1 at -25.0 and Long Term at 0. Short Term Bank 2 at 23.4 and Long Term at 0.
Old Dec 8, 2015 | 02:30 AM
JagV8's Avatar
Those are weird (hugely reducing fuel bank 1 but adding on bank 2).
Doesn't appear to be an air leak. Maybe bad cat conv. Sometimes you can tell by checking the temperature down the cats (IR gun/etc).
See who else has ideas.
Oh - if you get the codes again the freeze frame data might give clues.
Old Dec 10, 2015 | 10:30 AM
Illu187's Avatar
I checked the temps of the cats, the one in the front was about 202F and the one by the firewall was about 100F. These are the freeze frame data for P0300.
Old Dec 10, 2015 | 04:27 PM
topanga's Avatar
With that data, it looks like an air leak, that bank 2 fuel trim is way too high and the intake manifold absolute pressure should be about 9-13inHg. I had a similar problem recently and it was the PCV breather hose, even though it looked ok. Have you got the modified version fitted to yours?
Old Dec 11, 2015 | 05:08 AM
JagV8's Avatar
Or if the cats are very different it may be damaged.
Old Dec 26, 2015 | 04:39 PM
Illu187's Avatar
changed the pcv hose and it reads about 12inHg at idle. when driving it goes up to about 25inHg. i have checked all of the hoses and none i feel or hear a leak.
foxbottom
Aug 28, 2023 04:03 PM
Brentcon01
Jan 25, 2017 02:34 PM
Winston Gilbert
Feb 11, 2016 02:32 PM
dennis black
Dec 28, 2015 08:56 PM
Celticblood
Nov 14, 2015 10:36 PM
