Buying a X-type tomorrow
Old Mar 22, 2012 | 09:36 PM
mdxn17's Avatar
Default Buying a X-type tomorrow
hey im buying a Used 2004 Jaguar X-Type 3.0 Sport tomorrow and I just wanted to know what should I look at before buying this car. First of all, this is going to be my first jaguar and I know nothing about them. These are the spec and info the seller put.
Up for sale is a gorgeous 2004 Jaguar X Type 3.0 AWD. The color is Zircon Blue metallic with a Stone Grey leather interior. As you can see in the pictures, the paint shines beautifully and gets washed and waxed regularly. The car runs and drives amazing, no issues, all major services completed on time by Jaguar dealership. The car always turns heads and gets a ton of compliments everywhere I go from people who think it is worth 5 times more than it actually is! Oil religiously changed every 3000 miles. Factory options: All wheel drive - 3.0 litre V6 - 227 hp - 5 speed automatic transmission Mileage: 92xxx (11,000 miles/year) Full leather interior 8 way power front seats with lumbar support Premium package with Homelink garage transmitter, on board trip computer Burlwood interior trim Stone Grey leather Xenon headlights Power sunroof/windows/mirrors Factory alarm with keyless entry (have BOTH keys) 2008+ style factory front grille European spec chrome bumper blades Aftermarket accessories: Kenwood GPS/DVD headunit with Bluetooth 18" Stern wheels - hypersilver Falken FK452 tires - brand new (replaced in December 2011) - less than 3000 miles on them KW Coilover suspension - top of the line - fully adjustable ride height (+ or - up to 3.5") - rides amazing Mina Gallery catback exhaust with Porsche exhaust tips K&N air filter - never needs to be replaced, only cleaned every 3000-4000 miles.
With that being said, when I check out the car, what should I check out before getting it??
Thanks!
Old Mar 22, 2012 | 11:44 PM
Thermo's Avatar
Veteran: Navy
mdxn17, the big thing with this car is to take it out for a drive and listen for a whine from under the car. This is going to indicate 1 of 2 problems. The least of your worries is the centering bearing on the rear driveshaft. This is known to generate vibrations and noises when you get above 45 mph. It will feel like the seat has a vibration mode to it.
The bigger of your issues is the transfer case going out on the car. This will be evident by a whine at most speeds. Beyond that, working on this car is not much different than working on any other car.
One bit of caution I will tell you is that this can be an expensive car if you are looking for something to have fun with. If you like to use power to get off the line, you will more than likely be replacing transfer cases every 30K miles to the tune of about $3000 (USD). The X-Type is a good touring car and is great for getting out on the road and having a nice ride at a constant speed. But, if you are looking for a "sports car", this is not it. You would be better served by getting the S-Type or even stepping up to the XJ. Both of these cars will run you a few thousand more, but will not cost you as much in the long run.
The other thing I would tell you to try is doing a higher RPM acceleration (ie, above 3,000 RPM) with the car. Take the RPMs up to say 4,000 to 5,000. If the car bucks when you hit 3,000 RPM and does not want to go above 3,000 RPM, then there are issues. It is one of the safety features built into the car. I would still say to look into the car as this may be one of those things that you can use this "problem" to knock some money off of the car and then turn around and fix it yourself for fairly cheap in some cases.
Old Mar 23, 2012 | 10:55 PM
Danny A Fish's Avatar
Parking brake is worth checking as these are prone to seizing. Bubbling of the window sills due to rusting. If you find issues, these are both bargaining chips rather than show stoppers. Transmission whistle between 25 to 30 mph at low temperatures (1 or 2C or less) could be alarming but is also a peculiarly specific and common feature of the X that doesn't seem to be an indicator of anything very serious, - there are some suggestions on here about how to cure it.
Old Mar 24, 2012 | 09:44 AM
Spooky pantz's Avatar
Did you buy the car? It sounds great and it has a lot of nice mods. Post some pics
Old Mar 24, 2012 | 09:51 AM
JagXster's Avatar
Open the passenger door. Check for rust inside the door behind the lower hinges on the inner fender. Rust may also extend to the sills.
Old Mar 24, 2012 | 04:15 PM
ez53436's Avatar
I'm about 100% sure this is ufox8mycow's car for sale.
Old Mar 24, 2012 | 09:28 PM
ufoz8mycow's Avatar
Indeed it is. No deal, damn check engine light came on this morning. His mechanic we took it to said it was throwing a lean code.. Having my Jag mechanic take a look at it Monday to see what the devil is wrong with it.
Old Mar 31, 2012 | 10:29 PM
mdxn17's Avatar
yeah there were alot of problems but did you ever get the chance too fix it??
Old Apr 1, 2012 | 09:38 AM
iownme's Avatar
What was/is the selling price?
Old Apr 1, 2012 | 02:53 PM
mdxn17's Avatar
he was asking $8500
Old Apr 1, 2012 | 07:05 PM
Gold_04_X-Type's Avatar
It appears he already sold it...
https://www.jaguarforums.com/forum/x...-jumper-70743/
Old Apr 1, 2012 | 08:36 PM
iownme's Avatar
Wow...good price with all those extra goodies
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
DustysSon
Sep 13, 2015 04:17 AM
Whitnessmouse
Sep 4, 2015 11:09 AM
