Check engine light?
Old Jun 22, 2014 | 04:35 AM
ropetec007's Avatar
Default Check engine light?
Hi all, check engine light came on yesterday but car runs normally!
Any ideas on what it could be?
Jon
Old Jun 22, 2014 | 05:18 AM
fourbyfourbyfar's Avatar
hi you will need to get the codes read as it could be anything if it hasn't gone into limp mode chances are it's not too serious
Old Jun 22, 2014 | 09:02 AM
JagV8's Avatar
+1 on codes, a reader is very cheap
Old Jun 22, 2014 | 01:51 PM
Thermo's Avatar
Veteran: Navy
Jon, odds are, you are dealing with something fairly insignificant like a small vacuum leak. But, like the others have said, the codes will tell you a lot about what the computer is not liking. With the codes, we can then tell you pretty much down to the component what will need some TLC.
Old Jun 26, 2014 | 06:37 AM
ropetec007's Avatar
Apparently the lambda sensors are okay but the fuel came up as lean, I don't use super market fuel!
The light cleared a few days back but came on again today...... Stumped as no fault codes came up!
Old Jun 26, 2014 | 10:12 AM
JagV8's Avatar
The "fuel" can't come up lean. The car can be running lean, which often means you have an air leak. It'll likely ruin in your cats if ignored... Should fail MoT.
Old Jun 26, 2014 | 03:45 PM
ropetec007's Avatar
So if I have a possible air leak, how do I check or is it a garage job?
Thanks all for help so far.
Old Jun 26, 2014 | 04:02 PM
JagV8's Avatar
Back to codes. Get an OBD tool with live data so you can look at trims. Search on here for others who've done this.
Old Jun 26, 2014 | 09:26 PM
Thermo's Avatar
Veteran: Navy
ropetec, the X-Type normally suffers from 3 common vacuum leaks. The first one to check is the brake booster line that runs from the top of the intake manifold to the brake booster cylinder. Where you want to especially look is at the "football" (actually it is a check valve) in the middle of the line. Rub the plastic and look at it. If the plastic is crumbling in your hand or it looks like you have a crack in that piece, replace that hose (brake booster line). Next, remove the cover off of the engine and then look to the left of the intake tube. You should see a line the diameter of your thumb running from the front valve cover to the intake just downstream of the throttle body. Check the underside of that hose. Do you see a split in that hose? Is the hose ribbed? If the hose is smooth or you see a split, you need a new hose (PCV valve hose). Finally, if you are looking at the engine, look to your left on the intake. You should see 2 large black circles on the end of the intake. These are you tuning valves for getting more power out of your engine at higher RPMs. Undo the top valve by removing the 2 screws and pull the valve out about 3 CM. Is the o-ring there in good condition and green in color. If the o-ring looks questionable or is black in color, replace both o-rings (on a side note, the lower o-ring will require a little finesse to get out, you will undo the 2 bolts, slide the IMT valve out slightly, then you will need to get ahold of the old o-ring and then stretch it to slide over the end of the IMT valve, otherwise you are goign to have to pull the top half of the intake off to get at that o-ring).
This will give you a start as to where to find your problem. Granted, having the CEL light on and no codes has me a little confused. At a minimum the shop should have gotten the P1111 or P1000 codes.
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
