Cylinder number locations
Old May 18, 2020 | 09:56 AM
ken736cc's Avatar
Default Cylinder number locations
Hi Sorry to start a new thread about this. I keep getting conflicting information regarding cylinder location for a 2002 X Type 2.5. I need to know for certain that cylinder number 5 is the far left rear cylinder as viewed when sitting in the car. This is a U.S. model so this would be drivers side rear bank.
Ken
Old May 18, 2020 | 10:10 AM
avern1's Avatar
Sitting in the car the cylinders closest to you from right to left are #1, #3 and #5. The cylinders are located closest to the passenger compartment.
The cylinders closest to the radiator are #2, #4 and #6 from right to left.
Old May 18, 2020 | 11:10 AM
NBCat's Avatar
Here is the cylinder numbering scheme for the AJ-V6:
Old May 18, 2020 | 11:25 AM
Thermo's Avatar
Veteran: Navy
NBCat, some engineer must really hate techs. Why would you take the same engine, fire it in the same sequence (ie, 2 cylinders nearest the front of hte engine, the 2 in the middle, then the 2 on the back side), but, give the motor a completely different cylinder numbering all because it went into a different car. That makes about as much sense as shoving bamboo under your fingernails.
Old May 18, 2020 | 11:36 AM
NBCat's Avatar
That's because JLR adopted the ISO specifications, which changed the numbering sequence from what was previously used.
Old May 18, 2020 | 12:51 PM
ken736cc's Avatar
Thanks for all the help. I nearly changed the coil on cyl 1 instead of cyl 5. P0305 misfire.
Ken
Old May 18, 2020 | 01:52 PM
JagV8's Avatar
They didn't.
Jaguar took a long time to follow the international standards. You're seeing the results of before & after.
Following the standards means things like OBD tools report the cylinder / injector number consistent with the car
John Jones
Aug 24, 2018 01:22 PM
Dale Dunn
Mar 5, 2017 12:26 PM
Brandon Wright
Sep 1, 2016 04:38 AM
NDW
Sep 30, 2013 07:37 AM
mshrull9988
May 12, 2012 07:23 PM
