DriveShaft help?
Old Dec 12, 2017 | 06:34 PM
Savage Cheeto's Avatar
Default Driveline help?
Can any one help me, driving to work and my rear driveline bolt broke off. can I extract the studs and replace new bolts or get a whole new drive line. suggestions welcome.
Attached Thumbnails DriveShaft help?-20171212_153125.jpg   DriveShaft help?-received_10203763622446837.jpeg
Old Dec 12, 2017 | 06:43 PM
motorcarman's Avatar
There is not enough of the rear CV left to bolt to the flange.
Looks like a new CV joint or good/used propshaft is in your future.
bob
Old Dec 12, 2017 | 06:47 PM
I haven't seen a cv joint connected to the rear diff, but ill have to do more research.
Old Dec 12, 2017 | 08:31 PM
Looks like all the CV '*****' are GONE!!!!!!!!!!!!!!
bob
Old Dec 13, 2017 | 03:17 PM
bob thanks for the info but I was mistaken on the terminology, this is the center driveline not axles.
Old Dec 13, 2017 | 05:11 PM
The propshaft uses Constant Velocity Joints instead of Universal Joints.
The CV AXLES ALSO use the same type of joint.
No mistake in terminology.
Constant Velocity is a type of joint, not a complete axle or shaft.
bob
Old Dec 17, 2017 | 11:40 AM
Thank you Bob, now that makes sense. I was confusing the joint. Any way to order that joint, or would it be best order a new drive shaft. Looking at that joint I only have the metal o ring left.
Old Dec 17, 2017 | 01:23 PM
avern1's Avatar
Do search for DrDme. He is a forum member who parts out the X-types. He will have everything you need.
Old Dec 17, 2017 | 10:01 PM
Thang Nguyen's Avatar
Replace the whole center axle and new bolts and nuts.
lc3566
Sep 22, 2018 12:09 PM
Muamin
Feb 10, 2016 08:36 AM
Dr. V12
Aug 20, 2013 08:18 PM
Yorkiemark
Nov 3, 2012 05:10 PM
bojangles
Jan 24, 2008 11:21 AM
