Gas Cap cover stuck
Old Jun 22, 2008 | 12:37 PM
ahbrit's Avatar
Default Gas Cap cover stuck
Takes alot of wiggling with the lever to get it to open
Any ideas?
even bad ideas would be welcome
Old Jun 22, 2008 | 03:58 PM
FactoryJaguarTech's Avatar
Default RE: Gas Cap cover stuck
Probably coming apart in the back.
Open the cover and look at the aluminum spring. Should be even upper and lower. We replace alot of the springs and the latch housing. Dealer only for this one too.....they will know what you are asking for.
Old Jun 22, 2008 | 06:18 PM
jvegas's Avatar
mine did this. There are two metal things that grab the door. I just spread them apart a lil and it fixed the problem.
Old Jun 24, 2008 | 11:42 AM
bluejaggg's Avatar
mine did it aswell. the metal "things" got all bent up soI had to fix them. Then my actual latch release broke. Somehow a spring fell off and it wouldn`t re-latch. I had to manually open my gas cap on my last jag
Old Jun 24, 2008 | 03:19 PM
ahbrit's Avatar
How do you manually open it?
I thought it only opened by the lever
Old Jun 24, 2008 | 04:55 PM
bluejaggg's Avatar
The latch that connects to the door was gone on mine. The cable attached to the lever was completely disconected. and somehow the spring was missing.
Also the 2 metal "things" that always get bent out of place were pushed in all the way. So they didnt push the door open
That left my gas door just attached by the hinges. The hinges were stiff so the door wasnt flapping around it just stayed closed untillI slid a fingernail under it and opened it at the pump.
Old Jun 25, 2008 | 12:19 PM
hankycbr's Avatar
My metal springs are so bent and warped, I have no idea which way they should be going?
anyone have a picture of their gas cap so I can bend the metal wires appropriately?
thanks in advance!
Old Jun 25, 2008 | 10:51 PM
bluejaggg's Avatar
adjust them so they act as a spring.
Russ Graber
Feb 23, 2019 11:59 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
texaspete
Sep 10, 2015 08:34 AM
RedRider48
Sep 7, 2015 09:41 PM
jfitzoz
Sep 7, 2015 04:28 AM
