Gearbox Fault
Old Nov 23, 2007 | 11:32 PM
Striker27's Avatar
Default Gearbox Fault
I took the car out yesterday went to a few places and on the way back home I got the dreaded gearbox fault. I have anyellow light on the dashand the message centersays cruise not available as well as saying gearbox fault. I had a similar issue back in August and the dealerreprogrammed the computer. This time the car went into limp mode and had basically bucked a few times on the ride home. It is strange I went over a bump in the road and WAMMIE this happened!!!!
When I pulled the codes I am getting a P1643. So basically I am not getting info from the TCM module
Any help would be appreciated....
THANX
Old Nov 26, 2007 | 08:48 PM
Striker27's Avatar
Default RE: Gearbox Fault
I think I will just take it to the dealer then.
THANKS for all the help....
Old Nov 27, 2007 | 11:52 AM
aquill1's Avatar
You know what the code means than right? If not, CAN Link Engine Control Module/Transmission Control Module Circuit/Network....sorry though I tried to search online for a possible resolution of your problem...unfortunately that seems to be a not too common problem on this forum as well as the web in general...seems like the dealer or reputable shop is the way to go...sorry[]
Old Nov 28, 2007 | 02:38 PM
There ya go striker
P1643 Fuel Pump Monitor Circuit Low Input
Good luck
Jim
Old Nov 28, 2007 | 03:39 PM
aquill1's Avatar
Thats what that means jim?
Old Nov 28, 2007 | 04:27 PM
Striker27's Avatar
yeah I was under the impression that it had something to do with the TCM.
Old Nov 28, 2007 | 06:37 PM
jag_genius's Avatar
it does ... the code p1643 isn't a feedback for the fuel pump
P1643 is a Can network fault between ecm and tcm.. very hard to figure out.. even at a dealer... most times it's the harness failure.. between ecm and tcm. But good luck.
Old Nov 28, 2007 | 07:44 PM
aquill1's Avatar
Good luck!
Old Nov 29, 2007 | 09:42 AM
Striker27's Avatar
So far the dealer has diagnosed a failed TCM module and they are looking at the wiring harness for the problem.
I am wondering now if this could have been the issue for my battery light!!!
HMMM?????????
Old Nov 29, 2007 | 10:01 AM
aquill1's Avatar
What'd the battery cost you? 140?
Old Nov 29, 2007 | 12:47 PM
Striker27's Avatar
No they were unable to diagnose the Battery Light problem that I was having in the summer and chocked it up to some sort of fluke in the system. I am hoping once they retrace some of the wiring they will find a problem and be able to solve the problem I am having with the Gearbox as well as the Battery Light.
But I can only hope..........
A new battery I think costs me somewhere in the neighborhood of $100 bucks. It did not solve the Battery Light issue.
Old Nov 29, 2007 | 01:33 PM
aquill1's Avatar
You get special pricing? Cost from a dealer I thought was around 140 I paid 120 for a deka battery. Why don't you have them check out your fobs while you are at it?
Old Nov 29, 2007 | 05:17 PM
Striker27's Avatar
I received two brand new fobs when I got the car so I am hoping they are ok. The battery is a generic one and nothing too special.
Old Nov 29, 2007 | 09:15 PM
aquill1's Avatar
Hmmm...Thats strange...
Old Nov 30, 2007 | 07:09 PM
jag_genius's Avatar
the battery light is a faulty melting battery cable... with the can failure code they can only guess... tcm ecm or 1 of 2 harness's
Old Dec 3, 2007 | 03:02 PM
Striker27's Avatar
Turns out the TCM was bad. MAy have been due to water getting inside of it.. Not quite sure about the whole thing yet. Dealer is still working on it.
JaguarLover101
48
Jun 12, 2023 10:28 AM
3lvis
Oct 1, 2015 01:56 PM
dmatthewman
Sep 30, 2015 10:10 AM
jjmiah217
Sep 28, 2015 09:09 AM
