Has anybody taken apart a 2005+ fuel pump?
Old Apr 15, 2019 | 04:31 PM
Spikepaga's Avatar
Default Has anybody taken apart a 2005+ fuel pump?
Gents;
Has anyone anyone taken apart a 2005 or later fuel pump?
I ask, because fuel pumps up to 2003/4 can be “rebuild” or fixed by taking them apart and replacing the actual electric pump actuator inside the “bucket” . I am not sure if the same is applicable for later pumps as they are different .
Thanks for any help
Old Apr 15, 2019 | 07:36 PM
Dell Gailey's Avatar
I have tons of pictures of my replacement fuel pump and it looks exactly like an earlier year one. Idt they changed that pump as listing (depending on the "pigtail" or "elongated pin" electrical hookup) runs from 2002-2009 on replacements.
Old Apr 16, 2019 | 01:49 AM
Spikepaga's Avatar
Thanks Dell. If you have any photos you could share of the later pump, specifically of the area ok top of the bucket. I am not sure if the fuel pump motor connector is the same on both pumps
Old Apr 16, 2019 | 04:03 PM
In my thread on replacing my fuel pump there is a very comprehensive and detailed explanation of installing with input from a bunch of other members including pics, measurements, etc. The biggest challenge was/is the electrical connector on top of the pump. Either a "pigtail" or "elongated" hook up that apparently cannot be determined by vin, year or other information readily available. Even the Jaguar dealer said until his mechanics drop the tank and remove the pump, they have no way to know which one to order for replacement.
This is the "pigtail" type electrical connector =
Old Apr 17, 2019 | 08:39 PM
dennis black's Avatar
20 Year Member
here in the northeast you can get a pump for $125 used ....plentiful here
Old Apr 23, 2019 | 05:03 PM
Spikepaga's Avatar
Well I was able to source a genuine pump electric pump that looks identical to what other members have posted.
Challenge remains cutting the hole, removing the pump with gas still in the car and doing it safely.
Old Apr 23, 2019 | 06:20 PM
https://www.jaguarforums.com/forum/x...-205696/page2/
domino_z
Aug 3, 2015 03:34 AM
scottatl
Oct 31, 2014 10:01 AM
chernobee
Mar 24, 2012 12:38 PM
rodknock95
Aug 12, 2008 12:54 PM
