Help Airmass wiring diagram
Old Apr 27, 2017 | 08:10 PM
eurocare's Avatar
Default Help Airmass wiring diagram
Help, i bought a jag xtype 2002 and having a problem with the airmass wiring connection. can someone help me give the wiring setting of the airmass sensor who has the same model would appreciate much.
this is mine.
Old Apr 27, 2017 | 09:05 PM
avern1's Avatar
Follow the link below and you can download the wiring diagram for the 2002 model year and it will have the wire color sequence.
JagRepair.com - Jaguar Repair Information Resource
Old Apr 27, 2017 | 11:13 PM
eurocare's Avatar
Thank you! great help.
Old Apr 27, 2017 | 11:17 PM
eurocare's Avatar
airmass wiring diagram fixed! next problem now is rpm wont go over 3000! haist!
Old Apr 28, 2017 | 06:14 AM
JagV8's Avatar
Is that when driving? Probably rev limit if parked, to protect the car & trans.
Old May 1, 2017 | 03:31 AM
eurocare's Avatar
both. when on idle and in running. also i heard a popping sound on the intake, but when i remove the TPS socket it will gone, also the brake will normalized from stiff to normal, but as soon as i plug it again the popping noise will be back and the brake will stiff again.
Old May 1, 2017 | 07:45 AM
JagV8's Avatar
Air leak. Must be fixed. Many many threads you can read.
Old May 1, 2017 | 10:12 AM
Alfadude's Avatar
Sure sounds like a vacuum leak based on your description. The simplest, easiest and cheapest things to check first are:
-Brake booster hose. Not unusual to have those deteriorate
-IMT O-rings.
-PCV hose. If it is the smooth one, chances are it is split underneath. Newer style ribbed ones are much more robust.
There is a ton of information on all three of those issues.
Best thing to do is post the codes you have here as that would lead you in the best direction on where to start. If you have P0171 and/or P0174 start with what I mentioned above.
Old May 1, 2017 | 06:25 PM
eurocare's Avatar
Thank you Brother!,I will look into that. by the way, i forgot to mention that i have already new brake booster, new brake vacuum hose, new ICV or PCV, new TPS, replaced all spark plugs, replaced three (under intake manifold)of the ignition coils, resealed the IMT o rings, resealed the intake manifold, resealed the PCV hose and still having this problem. Fortunately i am still looking forward to be a long time partner of this cat!
