Horns not working
Old May 27, 2014 | 01:50 PM
Pastorrice's Avatar
Default Horns not working
Just acquired a 2005 x-type
The horns do not sound at all... Fuse is good, relays click when horn button depressed... Thought about whacking the horn with something while someone else has the button depressed ;-) I would have to find them first...
Any ideas?
Old May 27, 2014 | 03:00 PM
ltmax's Avatar
Do any of the other controls on the steering wheel not work? If so, it may be the clock spring under the airbag. These can go bad pretty easily.
Old May 27, 2014 | 04:52 PM
astromorg's Avatar
As the relay clicks, the clockspring, GEM, etc should be fine. As you haven't found the horns you won't have checked their earth/ground. The ground point is the outboard one of the two under the lefthand headlight assembly. The horns are under the battery box.
The relay might click, but also check that when it does, 12 v is getting through the relay to Fuse F38, 20A in the Main Distribution fuse box - the one under the hood.
Old May 27, 2014 | 08:00 PM
car5car's Avatar
Check horn connector with control light or multi tester.
Old May 27, 2014 | 09:29 PM
Pastorrice's Avatar
Default Update
Tested voltage at fuse box- solid 12 v when horn button pressed
Located horn under battery box- found connecter covered in duct tape
Removed super sticky tape
Unplugged connecter
Checked voltage at connecter, solid 12 v when horn button pressed
Bad horn?
Old May 28, 2014 | 09:28 PM
car5car's Avatar
If horn connector has voltage and ground, horn is possibly bad.
Check horn resistance, it should be 2-10 Ohms. Remove horn and connect it to battery using jumper wires. Sometimes horns have adjusting bolt, you need to adjust it.
If resistance is infinite, horn is bad.
Old May 29, 2014 | 08:57 PM
Cherry_560sel's Avatar
Just use the middle finger......lol...sorry I couldn't resist
Old May 30, 2014 | 05:46 PM
Pastorrice's Avatar
Cool
Resistance is 0
Both bad
Old May 31, 2014 | 02:33 PM
Pastorrice's Avatar
Thumbs up
Removed old horns- wire connecter also tested bad-
Bought after market horns of similar shape, bolted them on to the bracket.
Cut wire connecters and used butt connecters and 18 gauge automotive wire to direct wire the horns...
Works! Thanks for the help and ideas.
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
Bcrary3
Sep 12, 2021 05:41 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
philwarner
Sep 5, 2015 10:05 AM
