How to remove door speaker grill
Old Sep 10, 2012 | 09:22 PM
milesanddizzy's Avatar
Exclamation How to remove door speaker grill
I need to replace the front passenger door speaker grill on my X-type as it is cracked. From photos the grill seems to be clipped in so can it be pulled out easily? Or does the entire door panel need to be taken apart to remove the grill? Many thanks in advance.
Old Sep 10, 2012 | 09:24 PM
abonano's Avatar
I'm not an X Type expert - if it were me I would remove the entire door panel and not second guess if that speaker grille is held in by clips or not... Just my $0.02
Old Sep 11, 2012 | 07:59 AM
spielnicht's Avatar
You need to remove the door panel and then remove the glue around the 3 tabs holding it in place.
Make sure to get the right tool to help remove the panel without breaking the tabs (they will break otherwise, that's for sure).
Old Sep 11, 2012 | 03:05 PM
Patterson's Avatar
Default Jag Door Panel - driver
I happen to have my front door panels off. Here's a pic that might help you.
dsnyder586
Dec 29, 2024 07:39 PM
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
AL NZ
Sep 4, 2015 08:39 PM
