I am back for more! Window regulator – where to find?
Old Aug 24, 2010 | 02:19 PM
ruslan35's Avatar
Default I am back for more! Window regulator – where to find?
My front passenger window regulator went CAPUT! So, about a month ago I found after market version for about $100, but didn’t purchase, since I was leaving for vacation.
Now, I can’t find anything for less than $350 OEM.
My cat is 2002 X-Type 2.5L
Any help would be greatly appreciated.
Thanks!
Old Aug 25, 2010 | 12:17 PM
sidewalkman's Avatar
What went caput, the motor?
Old Aug 25, 2010 | 01:34 PM
ruslan35's Avatar
The motor is fine, plastic holders broke, which caused cables to chew up plastic roller on the motor and cables themself got bent
Old Aug 25, 2010 | 03:16 PM
youch.
Can you get them at a wrecker? I'll bet they will cost you a ton a the Dealership.
Last edited by JimC64; Aug 25, 2010 at 07:50 PM. Reason: Please refrain from using the word stealership!
Old Aug 25, 2010 | 07:51 PM
Try some of out vendors here ruslan,you might be surprised?
At least ask the question
Old Aug 25, 2010 | 08:01 PM
MarkC's Avatar
The window regulator for a 2002 Lincoln LS resembles that of the X-Type. They're all over EBAY and the internet for about $60. If you're handy, you may be able to cannibalize one for the parts needed to fix yours, or perhaps modify the LS regulator to work in the X.
Used parts is another approach. I've seen one for $100, which seems high, but other sources may be cheaper.
Old Aug 26, 2010 | 09:32 PM
dsickles's Avatar
try this guy, Ed: 2816562553.
i got about 10k worth of suspension parts for an s type for around 3 or 4k (all oem) and just picked up a brand new oem regulator for the same car for 180.
Old Aug 27, 2010 | 07:09 PM
gurn's Avatar
If you live close to a Pullapart yard look there for a Lincoln or Contour one, maybe the same also? they let you carry in your old part to match and prices are dirt cheep. I've saved a ton on SAAB parts with them.
Old Aug 29, 2010 | 01:26 PM
pnyklr's Avatar
Mine went I bit the bullet and got it online from Gaudin Jag in vegas was a lot cheaper then the dealer
fast40driver
Apr 19, 2024 07:24 AM
msdg137
Sep 16, 2015 06:24 AM
cheaperts
Aug 30, 2015 06:48 PM
Jandreu
Aug 29, 2015 07:31 PM
dpappyp
Aug 27, 2015 06:31 AM
