jaguar senta 20" on jaguar x type?
Old Jan 25, 2012 | 04:36 PM
kalacho2006's Avatar
Default jaguar senta 20" on jaguar x type?
some body put some jaguar sentas on a x-type,what tire size is better to it?
Old Jan 25, 2012 | 10:31 PM
exexpat's Avatar
Yes, they are possible depending on how bad you want it to work. For me, this is just par for the course, but as many people read on, most would think it sounds to involved to bother. I think those wheels would look awesome on an X-Type and I encourage you to do it - you will officially be the second X-Type owner I am aware of with 20" Sentas mounted (first being Allen from Las Vegas - ufoz8mycow username)...
You would need 25mm spacers in the rear wheels as they are 20x9.5 with ET66. They need to be closer to ET41 and the 25mm spacer will give you that. Fronts are 20x8.5 ET49 and are very close to working without spacers, but I would do a 5mm spacer to ensure you don't hit inner fender at full crank.
Spacers can be custom-ordered from www.motorsport-tech.com and your specs are: Front 5mm thickness, 63.4mm center bore, 5x108 bolt pattern (5mm will work with factory studs and lug nuts). Rears are 25mm thickness, 63.4mm center bore, 5x108 bolt pattern and you want hubcentric to wheel and car hub.
Tire size is 235/30/20 and I recommend the same on both front and rear axles to maintain same overall diameter.
Here is a picture of 20x9.5 OEM Volans wheels on an X-Type, but being the eccentric limit-pushing freak I am, I did 4 rears in 20x9.5 ET66 with 25mm spacers on all four corners...
Old Jan 26, 2012 | 06:28 AM
wow I likes your stile !!! yeah a guy on craiglist trade me 4 chrome 20" sentas for a usb mp3 car stereo 100 dlls value a good deal, the bad 2 wheels have 2 little crack on the back lip of the wheel not the big thing,but I want to repair the wheels and put on my car. look great I put 1 on the front and damn I fall in love with this wheels.
Exexpat thanks for the tips i think all the rims are 20x8.5,so any way I need the spacers on the back?
Old Jan 26, 2012 | 09:15 AM
exexpat's Avatar
If they are all fronts then you may be able to get by without spacers at all and the rears will be fine. Fronts will be thing to worry about, but if you do need spacers they will be tiny 5mm and those are inexpensive.
Old Jan 27, 2012 | 06:47 AM
This is my proyect car,103 k on it and run great so in tune up process, this pic with a senta wheel
Old Jan 27, 2012 | 09:54 AM
exexpat's Avatar
Nice. I normally hate chrome wheels, but these and on an X-Type are good.
Old Jan 27, 2012 | 11:43 AM
ufoz8mycow's Avatar
Hey Jeremy, what do you think of going +26 on a 9.5" rear? Something tells me it might be a little extreme....... or it could be awesome. Found a sick deal on a set of HRE's with perfect front sizing but the rear has the aforementioned +26.
Old Jan 28, 2012 | 03:25 AM
exexpat's Avatar
Nope. Those will sit 1/2 inch outside the fenders. Would work on a 18 or 17 with tire stretch, but not a 20.
Old Jan 30, 2012 | 04:54 PM
ufoz8mycow's Avatar
Yeah they were XKR fitment.... Too bad
Old Dec 26, 2013 | 12:56 PM
cyoung7569's Avatar
Default going for 20" senta wheels on xtype
So far I took expats advice and ordered 25mm spacers for rear and 5 mm for front im still nervous I ruff fit them with stock 265/35/20 and they hit strut and rubbed well so im going to order new 225 30 20 I hope that will clear strut and well
Old Dec 26, 2013 | 01:02 PM
cyoung7569's Avatar
Old Dec 27, 2013 | 08:48 AM
cyoung7569's Avatar
So i tried the front 8.5 on front They clear just bearly with the 25mm spacers i Orestes i tear They are going to stick out too much with 9.5 rears
Attached Thumbnails jaguar senta 20" on jaguar x type?-imag0692.jpg   jaguar senta 20" on jaguar x type?-imag0695.jpg   jaguar senta 20" on jaguar x type?-imag0689.jpg   jaguar senta 20" on jaguar x type?-imag0691.jpg
Old Dec 27, 2013 | 10:59 PM
04xtype04's Avatar
Whoa those 20" Volans look cool.
Old Dec 28, 2013 | 01:48 AM
they look good !!!! maybe if u put some 225/30zr20 tires it look better.
Old Dec 30, 2013 | 12:56 AM
exexpat's Avatar
those will work. You just need smaller tires and to roll your fenders. The rears sit about where mine do.
Old Dec 30, 2013 | 07:24 AM
Alfadude's Avatar
Expat is back! I haven't seen a post from you in a while showing the latest wheel creation on your X. Thought you might have gotten bored with the X and moved on. God to see you are still around.
Old Dec 30, 2013 | 08:17 AM
cyoung7569's Avatar
Thanks im going with 225 30 20 do u think thats good size to go with ?
Old Dec 31, 2013 | 12:21 PM
exexpat's Avatar
You might want to go with a 235/30/20 unless you know people who'll mount a stretched tire in the back. My first staggered set were 235/30/20 on all four.
Old Dec 31, 2013 | 12:23 PM
exexpat's Avatar
Bored yes. Sold no. Running 19x8 fake BBS with snow tires in 215/35 at the moment.
Old Jan 1, 2014 | 01:24 PM
cyoung7569's Avatar
Ok I just ordered seconds set of tires 235 30 20 I will send the 225 s back im just looking for clearance so ill show pics when I finally get spacers and tires mounted thanks Jeremy
