Just when everything was running smooth.
Old Oct 9, 2010 | 09:54 AM
Disco stu55's Avatar
Default Just when everything was running smooth.
So last night I was coming back from Calgary's, new mall. I was driving the speed limit, and as I went to pass a semi trailer truck. The rpm went to about 3300, and droped to 3000, and then the gear box fault message came on, aswell as the yellow caution light. The car drove fine, still accelereated, no probelms in any gears So once I dropped my friend I drove home turned it off and on again...nothing no probelms at all, started up just fine but the light was still still there, no check engine light or anything.
What gives?
Old Oct 9, 2010 | 11:32 AM
Thermo's Avatar
Veteran: Navy
Disco, get the codes read. They are still inside the computer even though the light is off. From the sounds of things, you are starting to suffer the dreaded throttlebody problem. But, before we start just tossing parts at the situation, lets see what the codes say. That may lead us in a more direct path to getting the problem fixed.
Old Oct 9, 2010 | 12:13 PM
Okay, I'm getting the rim finally put on and ill get the codes read to. F***k
Old Oct 9, 2010 | 12:14 PM
The vehicle seems to be operating fine, I was wondering if I should still drive it?
Old Oct 9, 2010 | 02:18 PM
Gold_04_X-Type's Avatar
My '04 does that all the time now. I will be at highway speed or decelerating, and the RPMs will jump, then the Gearbox Fault and amber lozenge light up.
The OBDII code I get is P0915, which is a 'gear selector out of range' problem. It means that the input to the TCM from the gear shift does not agree with the position of the gear selector switch on the transmission.
This particular code does not affect the cruise control so I have ignored it for the last 8 months.
Additional note: The P0915 code was added to the 2004 1/4 model year and did not exist in the OBDII of older X-Types. I don't know what code this problem would show up as on an `02 or `03.
Old Oct 9, 2010 | 04:02 PM
Intersting note GOLD, now my light is gone.....weird Ill have to wait till tuesday, everybody on Thanks giving break
Old Oct 10, 2010 | 09:38 AM
OKay, here it is, the one code is the catalytic converter effienciency bank 1. the second was manufacturer specific according to my friend. Its P1111, i have no idea what this means? and idea what the code is.
Old Oct 10, 2010 | 11:32 AM
P1111 is not a fault code. It is a special designator Jaguar uses meaning system ready, drive cycles completed after the last fault event. P1000, on the other hand, means system not ready, or drive cycles not completed after the last recorded fault event.
P1111 and P1000 cannot be erased.
Old Oct 10, 2010 | 11:45 AM
So...according to the computer...my cars okay?
Then why did the light come on?
possibilities..
- the one you described in the early post
- I read that sometimes, water builds up in The foot wells cuase a sensor or harness to though codes if it gets wet
- vibrations cuasing it come on
any other ideas, should I leave it be?
Old Oct 10, 2010 | 12:09 PM
Thermo's Avatar
Veteran: Navy
Disco, more than likely, your cats are starting to wear out and what you are seeing is the O2 sensors are seeing the limits being approached. So, occasionally, when you are driving, the limits will be exceeded, causing the light to come on. But, this is just speculation. You can try running a bottle of gas treatment through the car and seeing if you can possibly burn out some of the carbon in the cat. Sometimes it works, some times it don't.
Old Oct 10, 2010 | 12:34 PM
Thats what my friend at the shop said to, he says my cats might be plugged with carbon, he also told me this would rob the car of power, he didnt have time for a test drive cuase he had to get back to work. he told me itd not a throttle body probelm as far as he can tell.
Now, that leaves the question, should I get the cats cleared out, or replaced, which is costly according to my chemistry experience, cause they have precious metals that are in them, as well as pulling them out. or should i leave it be
Old Oct 10, 2010 | 03:16 PM
My other question if thats case, if its a problem with the cats, why did the car give me a gearbox fault light and message....
Old Oct 11, 2010 | 07:24 AM
It could be that on yours, the transmission code that was logged can't be read by a standard OBDII code reader. Some transmission and other codes require a more specialized code reader to access them.
Old Oct 11, 2010 | 11:30 AM
Hmm interesting, well Im going to get the brakes done on her, and a radiator fluch soon I hope, maybe ill fork up the 100 bucks and get it scanned by a more specialed tool
Old Oct 11, 2010 | 11:50 AM
dvd711's Avatar
Thermo, I have an 04 X Type, 2.5 with a similar condition as previously posted.
After car is warm, on acceleration get check engine light with code P0340.
Will try the gas treatment as suggested. If you could please answer a couple questions.
1. How do you remove LH cat? (one near firewall) does the front sub frame have to be removed?
2. Are the cats ceramic honeycomb?
3. Can you just remove ceramic and run straight?
Thanks...David
Old Oct 12, 2010 | 08:08 PM
More bad news, im getting a weird hissing sound whenever I turn her off, coming from the cabin airfilter area...
Also today when i was getting on the highway and acceleating, i heard what sounded like something that came off, and bounced and hit the car from underneath a few times on the passsenger side....
Whats happening to my car
I told the old man, and this weekend she might be wearing a for sale sign...
Old Oct 13, 2010 | 08:27 AM
Alfadude's Avatar
That sound you heard could be a wheel weight that came loose. You did recently change tires on the car. Only speculation and it doesn't happen often, but is a possibility. Had that happen to me once and the sound is kind catches you by surprise for sure.
trosty
26
Dec 18, 2022 06:40 PM
Doovoe
Sep 8, 2015 05:42 PM
kevo
Sep 8, 2015 09:45 AM
hen555
Sep 7, 2015 11:13 PM
