Key Fob Features
Old Aug 25, 2009 | 02:11 PM
Joeybronko's Avatar
Default Key Fob Features
Can my key fob be programmed to make the windows open or close? ala Audi. Are there any other neat features other than the norm?
Old Aug 25, 2009 | 10:55 PM
RickMG's Avatar
Originally Posted by Salank
So I think the battery in the key fob could be on its way out. Can i just get a new battery from somewhere and replace? Or is there some dealer only bs I have to do
See this thread here:
https://www.jaguarforums.com/forum/s...ead.php?t=2840
Old Aug 26, 2009 | 12:50 AM
BuckMR2's Avatar
Assuming your remote works with your car after changing the battery (ie you re-coded it to your car if you took too long to swap the battery) then you can...
Hold the lock button for more than 4 seconds all open windows.sunroof will close, this is called global closing.
Cant be used though to open the windows (global opening).
If you hold the lock/unlock button together for a few seconds the indicators will flash which switches between 1 and 2 stage locking/unlocking.
Old Aug 26, 2009 | 07:55 AM
kandA's Avatar
I was under the impression the global close only worked when you had the key in the door and hold it in the close position. Or is that something that works on the newer models (I have a 2002)?
Old Aug 26, 2009 | 11:27 AM
BuckMR2's Avatar
Global close worked on my 2002
Old Aug 26, 2009 | 02:42 PM
gupdah's Avatar
I have a 03 x-type, how do i do gobal closing, doesnt seem to work for me at the moment
Old Aug 26, 2009 | 02:47 PM
BuckMR2's Avatar
Press the lock button for over 4 seconds
Old Aug 26, 2009 | 03:26 PM
gupdah's Avatar
Iv tried that
Old Aug 27, 2009 | 01:26 AM
BuckMR2's Avatar
Must need enabling via dealer/specialist
Old Aug 27, 2009 | 07:51 AM
laura's Avatar
I asked my dealer about global close a while back when I read about it on a forum and realized my key fob didn't perform that function. It seems that U.S. models are not programmed for global close, only global open, due to child safety laws. However, as kandA stated, you can do global close by putting the key in the door lock and holding it in the close position.
MonacoDK
Jan 22, 2022 12:33 PM
redxk8
Sep 30, 2015 08:18 AM
Jzar
Sep 27, 2015 02:55 PM
buickfunnycar.com
Sep 25, 2015 10:02 AM
