Lugnuts
Old Jun 11, 2015 | 03:55 PM
RonnieJoe's Avatar
Default Lugnuts
Do the caps on the lugnuts of a 2004 X type come off? if so
how do you get them off?
Old Jun 11, 2015 | 08:10 PM
Thermo's Avatar
Veteran: Navy
Ronnie, the caps are not supposed to come off. They are supposed to be form fitting enough to allow a little bit of wiggle, but not much. if you find that they are getting too loose, you would have to probably use a dremel tool to get a slight rip in the covering so you can start peeling the cover off. Not sure if you can slide say a thin blade screw driver on the underside of the lug nut to work the cover off that way.
Old Jun 12, 2015 | 11:54 AM
dnorth1's Avatar
Get that taken care of/replaced now. Nothing worse then getting a flat out on the road and having those Dxxmn caps spin around the nut and not be able to remove the lug nut. Be there done that. Replaced all the capped nuts with solid chrome from LA Wheel
David N
Old Jun 12, 2015 | 01:51 PM
euanT's Avatar
These ones fit, and are SOLID!!! should be able to get them over your side!!
16 x TOYOTA ORIGINAL CHROME ALLOY WHEEL NUTS M12X1.5 LUG BOLTS | eBay
Old Jun 12, 2015 | 10:22 PM
wa3ra's Avatar
Euant called it; the Toy lugs (Scion, RAV4) are the cure!
Old Jun 13, 2015 | 07:44 AM
innzane's Avatar
The caps come off easy enough.
I had to remove them so the lugs would fit into my Dvinci rims.
That lil bit of metal gone gave me just enough wiggle so they fit.
Do not recall my exact removal process, but it was caveman for sure, no power tools.
Old Mar 4, 2019 | 04:48 PM
CyJag's Avatar
Just to chime, I bought some of the $30 Toyota lug nuts off eBay, as many others have done and suggested. They were fine (although they stick out a bit).
BUT after about a year, they are rusting on the outside. Going to look for a new solution.
Old Mar 4, 2019 | 08:02 PM
dennis black's Avatar
20 Year Member
these are the ones i got they are perfect had them on 2 years now
Amazon Amazon
Old Mar 5, 2019 | 04:58 AM
car5car's Avatar
I had much worse problem on some Jaguar. Stud was turning. I had to weld it from inside of hub.
RonnieJoe
Mar 4, 2019 04:47 PM
RonnieJoe
Jun 18, 2015 11:30 AM
Beerline123
Jun 16, 2015 01:59 PM
Grn03Str
43
Apr 11, 2011 03:03 PM
Cobra
Mar 9, 2011 10:19 AM
