no fuel pressure
Old Dec 20, 2010 | 02:33 PM
wjd03's Avatar
Default no fuel pressure
I have put a pressure guage on the fuel rail, no pressure. Before I go into the fuel tank, i want to ,make sure the inertia switch has not popped. I have a 99 xk8. It will start with startewr fluid but thats it. I pulled the passenger plastic trim (right of the feet) but cant find the switch......please help. Been reading this forum all day
Old Dec 20, 2010 | 02:36 PM
sidewalkman's Avatar
it's a little button, should be right there under the kick panel, I think when tripped it pops all the way out and you push it back in.
Old Dec 20, 2010 | 03:05 PM
wjd03's Avatar
Default re
I still cant find it. On the side , I see 5 connectors, and further nto the back of the panel I see more connectors and directly above is the heater motor. Can you be more specific?
Old Dec 20, 2010 | 03:07 PM
On the passenger side, you remove the rubber from the door and then take off the kick panel. I think there are 2 screws. I think the button is closer to the door end than the firewall end.
Old Dec 20, 2010 | 03:26 PM
wjd03's Avatar
Default re
you lost me man. I have the kick panerl off. no door rubber to trmove. Maybe we are talking about a different location. Is it in the door? I thought it would be behind the kick panel.
Old Dec 20, 2010 | 03:29 PM
wjd03's Avatar
i will now pull out my few remaining hairs
Old Dec 20, 2010 | 03:34 PM
wjd03's Avatar
did i mention its really cold (LOL)
Old Dec 20, 2010 | 04:39 PM
Alfadude's Avatar
This is the X-TYPE forun, not the XK forum. I think that is where the disconnect is in trying to find the inertia switch.Repost your question there you'll probably have more luck.
toronadomike
Jan 22, 2026 10:13 PM
silkcat
Jan 18, 2025 04:29 AM
dsnyder586
Dec 29, 2024 07:39 PM
Papelione
Sep 21, 2015 06:13 PM
ccfulton
Sep 20, 2015 05:15 PM
