OBDII codes
Old Apr 23, 2008 | 06:33 PM
FactoryJaguarTech's Avatar
Default RE: OBDII codes
The p1000 and p1111 are OBD readiness codes. Nothing to worry about. The P1646 is for O2 sensor bank1 upstream. Likely needs an O2 sensor.
Old Apr 24, 2008 | 03:55 PM
The two upstream are same part number and the two downstream are the same part number. Up and Down different from each other.
Bank 1 is on rear of motor and is the one closest to engine.
Old May 13, 2008 | 04:54 PM
You need to make sure that the wires have not been crossed somewhere. The P1646 is def bank 1 sensor 1 code. So you either have a wiring problem to that sensor or bad ECM. I would look at ECM last.
Fuse 21 (30amp) in the engine bay fuse box controls the heater circuit for that sensor. Check that fuse. Then you need to check fuse 19 (10amp) and fuse 36 (5 amp) all in the front fuse box. Engine bay.
Let us know.
Old May 14, 2008 | 04:16 PM
Mr_Miami's Avatar
Anyone have any to say about Pro Scan code readers?
http://www.myscantool.com/store/
Looking to get the bluetooth version.
Bcrary3
Sep 12, 2021 05:41 AM
philwarner
25
Jun 26, 2021 05:43 AM
scooternva
19
Oct 27, 2015 02:14 PM
drgrcr
Sep 25, 2015 10:31 AM
jehart49
Sep 12, 2015 05:36 PM
