Oil cleaning
Old Dec 27, 2013 | 08:51 PM
Noxparadise's Avatar
Default Oil cleaning
When I take my car in for an oil change (cold weather) they ask if I want to have their oil cleaner ran thru to clean out the engine excess gunk etc..is it worth it does it work? Anyone do this every so often? I've never had engine oil cleaning just regular changes pennzoil 5w-30
Old Dec 27, 2013 | 09:55 PM
Mikey's Avatar
Absolute waste of money.
Modern engines in good running order have no 'gunk' to remove.
Old Dec 27, 2013 | 11:40 PM
Originally Posted by Mikey
Absolute waste of money. Modern engines in good running order have no 'gunk' to remove.
Ok thanks I was skeptical just wanted to confirm.
I'm at 140,220 miles and never had it cleaned or cleaner ran thru it. Just was checking
Old Dec 28, 2013 | 09:34 AM
Thermo's Avatar
Veteran: Navy
Nox, if you really feel like you need something like this, go to your local auto parts store and find a product called "CD2". It is high strength oil detergent and it will do the same thing that they want to do. All you do is about 50 miles (or less) before your oil change, you add this bottle to the engine and do some driving. This will move all the garbage that might be in the engine to the oil filter and since you are pulling it out shortly thereafter, all is good.
Will you see miracles from this product, probably not. Most of the time when I see something from this product, it is from an engine that has not been well taken care of (ie, sat for a year and there are noisy valves). But, for an every day driver, most oils made these days will not result in sludge build up. If you are curious, simply remove the oil cap and using a flashlight, look down the oil fill hole. I bet you will see very clean metal with a nice layer of clear oil on things. If you are seeing "pudding" in there, then odds are, the CD2 product would benefit you.
Old Dec 28, 2013 | 11:13 AM
Originally Posted by Thermo
Nox, if you really feel like you need something like this, go to your local auto parts store and find a product called "CD2". It is high strength oil detergent and it will do the same thing that they want to do. All you do is about 50 miles (or less) before your oil change, you add this bottle to the engine and do some driving. This will move all the garbage that might be in the engine to the oil filter and since you are pulling it out shortly thereafter, all is good. Will you see miracles from this product, probably not. Most of the time when I see something from this product, it is from an engine that has not been well taken care of (ie, sat for a year and there are noisy valves). But, for an every day driver, most oils made these days will not result in sludge build up. If you are curious, simply remove the oil cap and using a flashlight, look down the oil fill hole. I bet you will see very clean metal with a nice layer of clear oil on things. If you are seeing "pudding" in there, then odds are, the CD2 product would benefit you.
Ok thanks I'll check out my oil inside to see.
Old Dec 28, 2013 | 12:06 PM
Alfadude's Avatar
And if you would see pudding in there I would bet you would have a whole bunch of other problems with your car. If the maintenance was kept up you are probably good. Spend your money on more important things.
Old Dec 28, 2013 | 02:56 PM
Doing oil change Running Mobil one synthetic and a high mileage oil filter, you don't need specific oil filer for synthetic do you?
Old Dec 28, 2013 | 04:14 PM
Mikey's Avatar
No.
Synthetic oil and fancy filters are added expense with no benefit unless you also extend the oil change intervals.
Old Dec 28, 2013 | 04:20 PM
Alfadude's Avatar
High mileage oil filter? Can't say I ever heard of that. Personly, my opinion is use a name brand of filter and call it a day. Same with the oil. Don't over think it. A bunch of threads on her about the right oil and the answer is always the same: use the right viscosity, change it regularly and you will be good. I have never seen a thread on here talking aboutan oil/filter related failure.
Old Dec 28, 2013 | 05:19 PM
No. Synthetic oil and fancy filters are added expense with no benefit unless you also extend the oil change intervals.
Like every 7,000 miles rather than 4,000?? Reason I was going to synthetic is due to cold weather bad start up noise..thinner for cold winter
Old Dec 28, 2013 | 05:49 PM
Mikey's Avatar
Factory recommended oil change interval using standard dino oil is 10,000 miles.
4,000 mile oil changes disappeared decades ago. Waste of time and money.
Old Dec 29, 2013 | 12:02 PM
Alfadude's Avatar
Your squeal on start up would not be from engine oil. If you had a sound at start up because of engine oil it would be because you didn't have any and the sound would be catastrophic grinding metal sounds. Top off your power steering reservoir with a correct fluid and if that doesn't fix your problem you probably need a new power steering pump. Not unusual on a car with 140K I would think.
Old Dec 29, 2013 | 01:21 PM
Yeah that's what I'm trying to do now, I got valvoline max life dex/mercon*LV and wanting to make sure this was within specs, all it says for Ford on the back is Merc*LV not sure if this is correct ?
silkcat
Jan 18, 2025 04:29 AM
aholbro1
Dec 29, 2024 06:46 PM
Rivguy
Dec 4, 2020 07:55 AM
jaaag
Sep 11, 2015 12:53 AM
Jag-o-nomic
Sep 4, 2015 03:07 AM
