Oil drip
Old Dec 26, 2008 | 03:19 PM
christo's Avatar
Default RE: Oil drip
Did you check your power steering fluid?
By the way - welcome to the forums and post some pictures of your car.
Old Dec 26, 2008 | 05:51 PM
Brutal's Avatar
its the oil pan gasket, very common
Old Dec 26, 2008 | 05:52 PM
Mike S's Avatar
Is the oil clean or dirty? Dirty its probably engine oil... clean sort of honey coloured its probably transmission / transfer case oil... I think many power steering fluids are reddish in colour.
This should give you an idea of where the oil is coming from.
Mike
Old Dec 26, 2008 | 07:28 PM
Dennis's Avatar
ud
OIL Pan Gasket..Like Brutal said..
Old Dec 27, 2008 | 01:14 AM
Luemasta32's Avatar
Anyone had there A/C compressor leak on em?
Old Dec 27, 2008 | 09:38 AM
Brutal's Avatar
ORIGINAL: Luemasta32
yes they do too, and the oil will be florescent yellowish/green.
Old Dec 27, 2008 | 10:57 AM
Luemasta32's Avatar
hhhhmmmmm very interesting Brutal. I've had a pretty odd oil leak ever since I bought the car. First was the oil pan gasket (classic one right there), but the shop I took it to said that they completely fixed my oil leak and that the remaining drops that I was still seeing where from the A/C compressor.
There is oil dripping off it, but it looks exactly like motor oil. I had no idea about the color of the oil so i've just been laying off my A/C (not the hardest task since it's been in the single digits in VT) .
I've just recently found another shop in my area that works on jag's. Thinking I'm gonna take it there for a second opinion. Have a date with the dealership to get a new key cut as well, thinking about having them do a once over of the whole car seeing as there about 3hrs away and would obviously know the car best.
Now the final question that remains is, where can a get a uncut key online that's not gonna cost me $275 at the dealership? I already know the process for programming the buttons so I would just need them to cut it.
Thanks again,
Mike
Old Mar 5, 2009 | 09:46 PM
Brutal's Avatar
you can program the remote, not the key, the key has to be done at the dealers..and take it in for an oil change and ask them about the ol leak when they have it up. I would never charge to tell you what i see and go from there. If it looks like engine oil, it is. Like I said, ac compressor oil is deglo green. theres no mistaking it. But since the lower bolts go into the oil pan they will drip engine oil when the oil pan gasket is leaking, making the not well informed think its the compressor
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
bdboyle
Sep 16, 2019 05:58 PM
BoarHawg
Dec 14, 2015 12:21 PM
ahunt4
Sep 25, 2015 03:43 AM
