Passenger Door Won't Open From Inside
Old Jun 28, 2012 | 09:41 AM
mthomas981's Avatar
Default Passenger Door Won't Open From Inside
2005 X-Type. The passenger door lock was not locking all the way with FOB or key so I pulled off the door panel to see what I could see. With the door panel off, the cable to the door handle seemed to be moving ok so I put everything back together. Lock seemed to work fine BUT now the door won't open from the inside. The lock is moving so I know the cable is in plaace. The outside door handle opens the door no problem. Any ideas?
Old Jun 28, 2012 | 09:48 AM
mthomas981's Avatar
sorry...the front passenger door.
Old Jun 28, 2012 | 10:29 AM
I've fixed your 'dorr' but can't help with the door.
Old Jun 28, 2012 | 11:49 AM
mthomas981's Avatar
LOL...thanks.
Old Jun 28, 2012 | 01:13 PM
Resident X-Type expert Thermo will probably see this question and give you the answer in a couple of sentences.
Meanwhile the JTIS Front Door Lock Actuator section may help. You don't have sufficient posts to download PDF's from the forum so I've put it on my MediaFire account. You can download it from this link:
Free Cloud Storage - MediaFire
The electrical or mechanical connection to the door lock looks a good place to start.
Old Jul 2, 2012 | 11:16 AM
mthomas981's Avatar
Anyone have any other ideas?
Old Jul 2, 2012 | 02:20 PM
Gold_04_X-Type's Avatar
The cable for the inside latch has a cylindrical molded head on it, similar to a bicycle brake cable. You have to make sure the cylindrical head is seating all the way into the receptacle on the inside door handle and rotated so the cable comes out at the appropriate point.
I did the same thing when reassembling a door panel and noticed that when it's not in all the way the door lock will not push in all the way.
Old Jul 2, 2012 | 07:02 PM
iownme's Avatar
There are many threads on this.
Likely cause is the actautor rod inside the panel needs to be adjusted...easy fix...takes about 30 minutes or less...keep searching the forum for more threads...there is a how to on doing it also...I had to do it when I first got my jag
99xk8guy
Sep 29, 2025 10:51 PM
VinnyT
72
Sep 28, 2025 12:17 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
TexasCat
Sep 8, 2015 04:36 AM
