Pecus Error E (Jaguar X Type - 2003)
Old Jan 3, 2014 | 12:00 PM
professor2hu's Avatar
Default Pecus Error E (Jaguar X Type - 2003)
1-3-14: Washington DC - I turned my car motor on, and I removed snow. Afterwhich, I noticed this on my display: PECUS ERROR E (with yellow-red flashing). In 10 years of ownership, I have never received this notice. What is the issue - what is wrong?
Old Jan 3, 2014 | 12:48 PM
Welcome to the forum professor2hu,
I've moved your question from Other Jaguar Models / Concepts / Replicas to X-Type forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post A NEW THREAD with some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jan 3, 2014 | 04:43 PM
I've run a forum search to see if we have anything on this error. The only thread I can turn up is this one:
https://www.jaguarforums.com/forum/x...e-3-0-a-45130/
If it's as simple as a discharged/failing battery then count yourself as very lucky! Certainly worth checking and eliminating this before assuming anything worse.
Other resources are low on information but suggest 'PECUS error' is a programming error and the 'E' indicates it is the ECM (Engine Control Module). This is likely to be a dealer fix or an Indy with dealer level diagnostics.
Old Sep 29, 2021 | 07:17 PM
Bogolepov's Avatar
Hello. I have solution for PECUS ERROR E on ecu denso. I try do it on jaguar x-type 2003 2.5. All work fine.
Old Jan 8, 2022 | 12:24 PM
JP88's Avatar
salut peut tu m expliquer comment tu fait pour corriger pecus error e , la voiture demarre et aucun defaut jaguar x type 2500 v6 de 2003 merci
Old Jan 8, 2022 | 03:14 PM
motorcarman's Avatar
Did you diagnose the fault or did you find out what happened?
Info for you.
File Type: pdf
Old Jan 9, 2022 | 01:57 AM
JP88's Avatar
Merci de répondre , j ai diag autel , j ai aucun défaut , j ai remplacer ecm ( flash eeprom ) demain je vais remettre ecm ancien et voir si toujours le défaut PECUS , j ai remplacer ecm car le moteur tourner avec 3 cylindre , et ecm abîme par l humidité
Old May 18, 2023 | 12:38 AM
majkellondek's Avatar
Hi,can you help me sort out pecu e error in my x type 2003 2.0 v6? denso x400 ecu.
How i can fix this?
Regards
John FH
May 1, 2019 05:26 PM
p911
Nov 21, 2018 12:36 PM
fifs0075
Oct 25, 2018 03:32 PM
emilio
Aug 17, 2017 02:43 PM
allenman85
Nov 28, 2014 12:17 PM
