Radio
Old Jan 22, 2008 | 12:56 PM
wanganracerx's Avatar
Default Radio
I looked through the X-Type post's and didn't see any thing about this, but I have been wanting to change the stock radio for an aftermarket DVD player since I got my Jag. The only thing is every where I go no one has an adapter kit for the X-Type. Does any one know a web sight or any body that makes one?
Old Jan 22, 2008 | 01:04 PM
jvegas's Avatar
Default RE: Radio
that is a headach! if you want the dvd set up just trade the car in for one that has it. LOL
Old Jan 22, 2008 | 01:10 PM
Default RE: Radio
lol... true...lol
Old Jan 22, 2008 | 01:21 PM
one's Avatar
one
Default RE: Radio
Your best bet is to do an amp bypass. This requires a rewire of the car, or a good technician that can jump the factory wires at the amp....... depends on your tech. Most are not capable of doing it. I owned car audio stores years back, MECP Certified Masters installer, and have a degree in Electronics Engineering....... I can do it blindfolded.
If you have a schematic of the wiring in the car, you can add the factory radio and use the factory amp by taking a set of raw RCA cords and fitting them to the wires behind the radio that go to the inputs of the factory amp. Then plug the new fittings into the RCA outputs of the radio. The RCA's drive low voltage out, which is made to go into the inputs of the amp. This will eliminate the need to spend $100 on the voltage reducer that they always try to sell you.
As far as a fit kit goes, I have not looked on the web for one.
Old Jan 22, 2008 | 01:28 PM
Default RE: Radio
Yeah, I thought of doing that and it would me easy but I don't wan't to cut up the wire's. That way if for some reason I decide to go back to the stock unit no one would ever know that it was taken out or tamperd with.
Old Jan 22, 2008 | 01:32 PM
one's Avatar
one
Default RE: Radio
You don't cut the wires, you T-tap them.
16 yr old's in '77 Ford LTD's with 6 color paint jobs cut factory wires...... Jag owners use T-Taps
Old Jan 22, 2008 | 01:34 PM
jvegas's Avatar
Default RE: Radio
That trade in looks much better now after reading the above post.... LOL
Old Jan 22, 2008 | 01:37 PM
Default RE: Radio
true. I seen some guys x-type on cardomain and he had the sweetest car kit, it looked stock. I asked him where he got it and the BA#$@RD didn't want to tell me. I will try to find the pick to show what I mean.
Old Jan 22, 2008 | 01:49 PM
Default RE: Radio
This is it, I think it looks realy good.
Old Jan 22, 2008 | 02:33 PM
Default RE: Radio
forget it I found a better kit. If any one had the same problem as me go to www.nexxia.co.ukthey have the Facia adaptor and the harness adaptor. Thanks for every ones help.
Old Jan 23, 2008 | 10:50 AM
aquill1's Avatar
Default RE: Radio
Hey wangan don't worry about it...are you familiar with mdf at all? There have been many that have made a dash kit. The hardest part is matching up the color of the climate control plastic to the face of the dash kit. Here's a link to a a how to a guy did. To get a wiring harness for the radio bigdreams used a ford harness on his s-type and I'd find it hard to imagine that they'd use a different one on the x-type. You'd be looking at $20 bucks worth of materials and another 7 bucks for the harness from your local walmart!
Old Jan 23, 2008 | 12:39 PM
H20boy's Avatar
Default RE: Radio
I can confirm that all my wiring harnesses on my 03 XK8 are Ford also. Stampted right on it. Pretty sure yours will be too.
Old Jan 23, 2008 | 06:16 PM
aquill1's Avatar
Default RE: Radio
Does that help wangan?
Old Jan 23, 2008 | 07:34 PM
one's Avatar
one
Default RE: Radio
ORIGINAL: wanganracerx
I've been staring at that picture for a day now wondering why it looks so weird..... finally I got it...... I've never seen manual climate controls.
Old Jan 23, 2008 | 07:44 PM
Default RE: Radio
Yeah that helps. I like that kit for sure! I will try to make one rather than order one. Thanks guys!
Old Jan 23, 2008 | 09:06 PM
aquill1's Avatar
Default RE: Radio
I assume you noticed that the link in my second to last post? If not it shows how to do that dash piece. Good luck!
Yeah one I was looking at that too but I noticed right away how weird it looks w/out digital climate controls.k I kind of like the look but I think I prefer our digital ones...
Old Jan 23, 2008 | 11:36 PM
Default RE: Radio
I agree. digital is better! and yeah I checked out that link. when I get it done I'll post up some pictures, Thanks aquill![sm=goodidea.gif]
Old Jan 24, 2008 | 01:54 AM
one's Avatar
one
Default RE: Radio
Manual climate controls = ford.
Digital = Jag.
Old Jan 24, 2008 | 10:09 AM
aquill1's Avatar
Default RE: Radio
Hey no problem wangan just make sure you take some pics of it all!
