Rear entertainment Install help
Old Nov 19, 2010 | 09:39 PM
04Xtype's Avatar
Default Rear entertainment Install help
Hi Guys,
Just got my rear entertainment system in today in the mail, and i was wondering if anyone knows a shortcut way to get the wire down the back part of the seat from the monitors? The instructions say that the seat is required to be removed, but just trying to see if it is necessary in case someone has another way to do it. If not, I guess I'll be takning the Seats out to do it. Is there anything I should know about taking the seats out of the car that may cause me to break or mess something up?
Thanks in advance.
Old Nov 20, 2010 | 02:10 AM
Jaggyx's Avatar
try a metal coat hangar to snake it through? just make sure not to puncture the leather.
Old Nov 20, 2010 | 01:09 PM
04Xtype's Avatar
i just got the wire to the bottom part of the seat, but was unable to get the wire out. Anyone have ideas of how to get the bottom portion of the seat open? I know there is a plastic clip (hook) type thing holding it together, but was unable to get it open. Just looked under the seat and saw that there are a lot of wires attached to the seat. dont want to have to take the seat out of the car if possible.
Old Nov 20, 2010 | 01:23 PM
Ian D's Avatar
I managed to do the install, with the UK version with the seats still in! You must unclip the plastic hook at the bottom its the only way of getting the cable out. Took me 3.5 hrs in all to do the whole install including cutting the centre console which is required for the UK version.
Old Nov 20, 2010 | 04:15 PM
04Xtype's Avatar
Ian D,
Is there a trick to unclip the bottom portion of the seats? I tried to undo it, and it would not come a part for me.
Old Nov 23, 2010 | 06:12 PM
Ian D's Avatar
you just gotta give it a pull, if you feel the clip you'll get how its held together, I pulled the two sides closer together and went from there. Its hard to explain. Just give a good old fashioned pull!
Old Nov 24, 2010 | 12:01 AM
gragner66's Avatar
did you get the kit that was on here for $127 or the one that is $250. i cant find thread for the $127 any more it has better pics to see what all your getting
Old Nov 24, 2010 | 12:50 AM
04Xtype's Avatar
Thanks for the info Ian D. Thats exactly how i ended up getting it apart. Took a while but worked like a charm. I finally got the screens installed. once i put everything back together again, w/o checking to see if the unit works, ended up finding that the unit where the connectors are does not power on. the screens have power, but only stuck on the card reader screen as no power to the unit. No light showing on the unit either. Going to have to take everything a part again and see if any connectors got disconnected when putting back together. good waste of a couple hours :?. Hopefully its just an install error and not the part itself.
Old Nov 24, 2010 | 09:38 PM
04Xtype's Avatar
Gragner,
I got the one that was for ~$130. the link should be easier to find on the S-Type page as thats where I saw it. Ill see if i can find and try to post.
Update on the install: Finally got everything connected and working. After about a total of close to 3 to 4 hours, finally got it installed and working. If I had to do it again, im sure I could have the install done in about 45 mins.
Old Apr 20, 2011 | 08:38 PM
aluni2230's Avatar
$127 shipped from Nalley Jaguar. I called them and mentioned the offer and they shipped it Fed ex. I ordered on April 13 and I got it today.
I have the champagne interior in my car. The components are high quality, but the leather color is slightly clearer than on my car. I called them and they said it was most likely the result of aging of the leather.
Old Apr 29, 2011 | 03:21 PM
sidewalkman's Avatar
I thought about getting it, but I'm 6'4 and nobody fits in my back seat so there is no point.
Old Apr 29, 2011 | 04:33 PM
aluni2230's Avatar
I noticed your car is the same color as mine. The interior color of my car is called 'barley', which I was told translates to the new 'champagne'. However, when I got the champagne set the headrest color was slightly clearer than the rest of my leather. The difference is subtle but obvious.
The quality of the components are really good and my local dealer would do a complete install for $350. So $127 + $350 is a great price.
In the end, I didn't do the install only because the resolution of the screen is only 240p for a 7 inch screen. Compare that with an ipad that is 720p and you can slip an ipad into the rear pocket if you like. A 16 GB ipad version 1 can be had for $299, or for around $600 you can actually get a pretty compelling alternative to the fixed rear entertainment system. Remember you still have to hook up an ipod or a DVD player with this system...
Great looking set, but in my opinion time and technology has just passed it by...
FrickenJag
Jun 16, 2025 02:15 PM
dsnyder586
Dec 29, 2024 07:39 PM
Dz1rfj
Jul 17, 2018 10:29 AM
fingers
General Tech Help
Oct 21, 2015 02:02 AM
Dz1rfj
Sep 16, 2015 03:44 PM
