Rear lights & cruise control out!
Old Oct 13, 2014 | 02:54 PM
k1e1v1i1n's Avatar
Default Rear lights & cruise control out!
Rear lights & cruise control are both out I am sure they are connected I can not find the fuse and i have searched and searched. any help would be amazing. the car is a 2005 x-type Canadian 3L v6.
Thanks in advance.
Old Oct 13, 2014 | 04:11 PM
JagV8's Avatar
You're not in a model-specific forum so that's nothing like enough info!
Old Oct 13, 2014 | 04:24 PM
I've moved your post from the General Tech section to the X-Type section where members with the same model can provide a better response.
As this is your first post, please stop by the New Member section and post an intro. In return, you will receive a warm welcome and some great tips on navigating the forum
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Enjoy!!
Old Oct 13, 2014 | 04:26 PM
Araho's Avatar
Default New
How did you post your question, I just joined and this is all very confusing.
Old Oct 13, 2014 | 06:17 PM
k1e1v1i1n's Avatar
No idea what I was thinking there. 2005 x type 3 liter
Hopefully that is helpful.
Thanks in advance.
Old Oct 13, 2014 | 06:22 PM
k1e1v1i1n's Avatar
I clicked on the "post new thread" button. its pretty easy its on the upper left side of almost every forum in the world.
Old Oct 13, 2014 | 06:53 PM
Welcome to the forum Araho,
Old Oct 13, 2014 | 08:01 PM
wa3ra's Avatar
Fuse panels are under the steering wheel on the firewall (it is easier to get at if you pull the small compartment near your left knee), and under the hood on the driver side just in front of the radiator tank, along the fender.
The cruise gets its run signal from the same circuit, there is switch on the brake pedal mounting bracket.
I'm not home, but I'm sure someone will pop in with the fuse number shortly!
Old Oct 13, 2014 | 09:27 PM
k1e1v1i1n's Avatar
Been playing in there all day. Still can't find the right one. My manual says nothing about break lights. Closes I found was manual transmission cruise control. But mines an auto.
Old Oct 13, 2014 | 11:00 PM
wa3ra's Avatar
F90 Mini 7.5 Brown Stop lights, cruise control.
Is in the passenger compartment fuse block. Lowest left side fuse, closet to the door.
Are ALL the taillights out, or just the brake lights?
Old Oct 14, 2014 | 08:38 AM
k1e1v1i1n's Avatar
Just the break lights.
bottom left is a red 10 fuse
the location is f12 my fuses only go up to the mid 50's.
Old Oct 14, 2014 | 12:05 PM
k1e1v1i1n's Avatar
Just an update I called the dealership and they said it could be fuse f51 or the switch on the brake pedal itself. so I will check those out and report back.
Old Oct 14, 2014 | 12:40 PM
k1e1v1i1n's Avatar
Ok I figured it out. after looking at the switch I knew right away what the problem was, It was just hanging by the wires. undamaged but just hanging in mid air. no screws on the floor no broken plastic. so i just put it back on, it has a twist fit.
I was like wow that was easy so i tried it out and nope still a no go. I went back down to find it felt lose and I cant see how to reattach it other then to add 2 screws witch i cant find. so its zip tied for now.
next problem is the pedal doesn't reach it by like 2-3 mm that seems weird like a small piece of rubber is missing like a foot to trigger the switch. so I'm using a piece of tape over lapped for now. I will have to order some parts I guess but as they work for now I can finely go get some groceries lol . Thanks for all the help and I hope this is helpful for someone in the future.
Shawn Svacha
Nov 4, 2019 02:47 PM
OkieTim
Sep 2, 2015 12:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
innzane
Sep 2, 2015 10:08 AM
