Steering wheel removal & reinstallation
Old Mar 19, 2007 | 06:19 PM
IronCobra's Avatar
Default Steering wheel removal & reinstallation
I just ordered a new steering wheel off of Ebay (wood and leather) and am wondering how hard this would be to install myself. Anyone have any experiance with this?
2003 X-Type
Thanks! Also, anyone insterested in buying a MINT condition Black all leather steering wheel (minus Airbag)? $50.00 plus s/h ($15 US shipping only).
Old Mar 19, 2007 | 09:22 PM
racerx82's Avatar
Default RE: Anyone removed and reinstalled a Steering wheel?
Should be an easy remove and replace....you will need a steering wheel puller or the good'ol dual hammer trick works well too...(if you're not sure what I'm talking bout, don't worry)
Old Mar 19, 2007 | 11:13 PM
BuckMR2's Avatar
Yep, mine came off when upgrading to cruise control
Old Mar 20, 2007 | 12:27 AM
IronCobra's Avatar
Cool, glad it's not too difucult. Any more details on this? I don't want to have a steering wheeless car because I screwed up.
Thanks!
Old Mar 20, 2007 | 01:33 PM
bigdreams05's Avatar
Make sure you disable the airbags, as you never know what can happen.
Old Mar 20, 2007 | 09:09 PM
BuckMR2's Avatar
When you disconnect the battery the air bag still has stored power.Here is how the JTIS explains removal:-
ALWAYS WEAR SAFETY GLASSES WHEN REPAIRING AN AIR BAG SRS VEHICLE AND WHEN HANDLING AN AIR BAG MODULE. FAILURE TO FOLLOW THIS INSTRUCTION MAY RESULT IN PERSONAL INJURY.
CARRY A LIVE AIR BAG MODULE WITH THE AIR BAG AND TRIM COVER POINTED AWAY FROM YOUR BODY. THIS WILL REDUCE THE RISK OF INJURY IN THE EVENT OF AN ACCIDENTAL DEPLOYMENT. FAILURE TO FOLLOW THIS INSTRUCTION MAY RESULT IN PERSONAL INJURY.
DO NOT SET A LIVE AIR BAG MODULE DOWN WITH THE TRIM COVER FACE DOWN. FAILURE TO FOLLOW THIS INSTRUCTION MAY RESULT IN PERSONAL INJURY.
NEVER PROBE THE CONNECTORS ON THE AIR BAG MODULE. DOING SO MAY RESULT IN AIR BAG DEPLOYMENT. FAILURE TO FOLLOW THIS INSTRUCTION MAY RESULT IN PERSONAL INJURY.
TO DEPLETE THE BACKUP POWER SUPPLY ENERGY, DISCONNECT THE BATTERY GROUND CABLE AND WAIT ONE MINUTE. FAILURE TO FOLLOW THIS INSTRUCTION MAY RESULT IN PERSONAL INJURY.
I would wait longer than one minute...at least 10 to let the charge drain from the capacitors.
Press the driver air bag module in whilst loosening the retaining screw.Loosen the driver air bag module left-hand retaining screw. Press the driver air bag module in whilst loosening the retaining screw.Loosen the driver air bag module right-hand retaining screw. Detach the driver air bag module. Disconnect the driver air bag module electrical connector. Remove the driver air bag module.Disconnect the driver air bag module electrical connector.
Position the front wheels in a straight ahead position and centralize steering wheel.
Remove the steering wheel.
Using a suitable insulation/masking tape, secure the cassette module to prevent movement from the centralized position.
To install, reverse the removal procedure.
Tighten to 47 Nm.
Take care not to damage or twist the driver air bag module cables.Attach the driver air bag module. Press the driver air bag module in whilst tightening the retaining screw.Tighten the driver air bag module left-hand retaining screw.Tighten to 5 Nm. Press the driver air bag module in whilst tightening the retaining screw.Tighten the driver air bag module right-hand retaining screw.Tighten to 5 Nm.Connect the battery ground cable.
There you go, easy
Old Mar 21, 2007 | 11:24 PM
racerx82's Avatar
Good info...
Old Mar 22, 2007 | 01:31 AM
andersen06's Avatar
Buck strikes again...
Old Mar 22, 2007 | 11:38 PM
Chalk up another one for the Buckmaster!
Added to the FAQ pages too
JC
Old May 21, 2013 | 01:44 PM
pegasus3710's Avatar
hi i have the 04 diesel classic doesn't have cruise control but if i upgrade to a cruse control steering wheel do i just swap them over or is there more to it than that
dsnyder586
Dec 29, 2024 07:39 PM
rusty37
Apr 5, 2020 07:40 PM
PMKimpton
Aug 3, 2019 08:22 PM
sogood
Sep 15, 2015 07:35 AM
AL NZ
Sep 4, 2015 08:39 PM
