stuck in park wont start 03 x-type
Old 07-24-2009, 07:16 PM
brisbon's Avatar
Default stuck in park wont start 03 x-type
i parked on a incline the other day and it was real hard to shift in reverse and it banged when it finally went. i hear this can cause a clip on the shift cable to break or lock up at the transmission side. but ive been able to shift it fine since ( 2 weeks now)
now the car is outside my shop and after a few key offs and ons i was able to move it and park it out of the way but now i cant take it from park or start it up and the battery is fine. im getting a gearbox fault message. anyone have this issue?
Old 07-27-2009, 08:06 PM
ant1.0's Avatar
Had that message come up while installing my dvd, bumped the shifter. Car wouldn't start ( gear box fault) same thing. Ultimately unhooked the battery and let it sit for about 20min. Reconnected the battery, started no problems since.
mmoriarty (11-01-2012)
Old 07-28-2009, 12:40 PM
BuckMR2's Avatar
PS If you ever need to move it from Park (say to neutral for towing? or incase the selector solenoid fails) lift the gaitor surround and there is a lever on the side of the selector mechanism which allows movement out of park when pressed in
Old 07-29-2009, 07:01 PM
brisbon's Avatar
yes thank you guys, and i read your write up on your sunday morning hotwire to the solenoid interesting. luckily after installing the radio the issue disappeared for good, i almost feared i was going to have to buy a new jgate assembly ($400) just for the solenoid.
I still dont get why its so bloody hard for us to find wireing kits or faceplates for radio installations on our jags. i wouldnt have had it not been for this site.
Old 07-29-2009, 07:31 PM
Jamey's Avatar
That is an excellent post.
Old 07-29-2009, 10:54 PM
ant1.0's Avatar
Thanks Jamey, as long as everyone helps each other, our only car trouble will be getting in there and doing it.
Old 08-01-2009, 08:54 AM
brisbon's Avatar
just some pics after wards. the base is g41 mitsubishi green i had left over from a car i did and nason clear coat.
shotty pics from my phone but its a deep green matallic.
Attached Thumbnails stuck in park wont start 03 x-type-img00148.jpg   stuck in park wont start 03 x-type-img00146.jpg   stuck in park wont start 03 x-type-img00145.jpg
Old 11-01-2012, 02:59 PM
mmoriarty's Avatar
Do you know why this worked? Having a similar problem (although re-occuring) so I'm just curious... (see https://www.jaguarforums.com/forum/x...neutral-83920/ )
Thanks.
Jpav27
07-31-2022 06:43 AM
cissdm
05-03-2016 06:02 AM
Rlover
03-30-2016 10:04 PM
tberg
09-07-2015 07:32 AM
Sprayall
09-03-2015 07:49 PM
Quick Reply: stuck in park wont start 03 x-type
