T-Case and Differential Fluid Change Questions
Old Jul 1, 2018 | 10:04 PM
AndrewG's Avatar
Default T-Case and Differential Fluid Change Questions
So I've looked around the forums here using the search tab and have not found a post that fully answers my questions I have. My car just crossed 128k and from what I know has never had the t-case or differential fluid changed. While the car doesn't show any signs of excessive wear at this point, I want to change the fluid now rather then when something comes up.
So my questions are for draining and filling the fluid out of each system. Can I just use a regular fluid pump? Or do I need to make some sort of custom fitting for each system to get the fluid out? I'll attach a picture off of google to show what I'm trying to describe.
Could the orientation of the vehicle help when using a regular fluid pump? So for example having the front end raised or back raised, or ether side.
Lastly is flushing required? Or can I just fill each system up until they are not accepting more fluid after draining the old fluid out?
I apologize since I know there have been many posts on this topic. My mechanical skills and access to tools are fairly limited, so I was hoping the clear my confusions up so I can tackle this project asap.
Thanks,
Andrew
Old Jul 2, 2018 | 12:22 AM
Dell Gailey's Avatar
Lots of posts on how to change transfer case. Do a search on here. Differential is straight forward. Suck out fluid with pump, fill with correct fluid.
example = heed post #9 =
https://www.jaguarforums.com/forum/x...-change-56648/
Old Jul 2, 2018 | 12:23 AM
https://www.jaguarforums.com/forum/x...change-173556/
Old Jul 2, 2018 | 04:42 PM
Btw, the transfer case is a fraking p.i.t.a. Look up my posts on changing fluids in transmission, transfer, differential, power steering. The pump I got had a very small black pipe adapter that when you remove the plug on the transfer case, the gears are right there interfering with getting the suction through and back towards the rear of the "holding" tank part. It holds so very little fluid to begin with, I wanted to get everything I could out before filling.
I chose the "14 second" method for my transmission and was very happy with the results.
Old Jul 3, 2018 | 01:48 PM
AndrewG's Avatar
Thank you a bunch for the replies! I think I can definetly do the diff myself, however I'm going to call my mechanic to hopefully get the t-case done by him.
Old Jul 3, 2018 | 01:55 PM
AndrewG's Avatar
The main requirements for the gear oil is synthetic 75w140 right? Should I avoid oils for limited slip diffs?
Old Jul 3, 2018 | 03:02 PM
Correct, my personal preference is Royal Purple. JEGS had a deal when I bought mine (3 pack).
Old Jul 3, 2018 | 03:09 PM
Btw, I highly doubt your mechanic will do the transfer case change. I've only seen 1 member so far who got one to do it. The tipping the car scares them, as the method of removal and refill (1 way of doing it). I chose the harder way.
Old Jul 4, 2018 | 06:48 AM
iownme's Avatar
replacing the transfer case oil is quite a simple job in itself, its jacking the car up 21" twice thats the PITA.
i recommend at least loosening the drain bolt before getting it up in the air in case it doesnt want to come out.
a 5' length of garden hose will fit inside the plug hole and can be fed through the wheel arch.
add a funnel in the end, that way you can easily get the new oil back in from the comfort of standing next to the car.
trying to get the new oil in from under the car is not the way to go.
this is not a job i would trust to a local mechanic
Dell Gailey
May 12, 2017 03:38 PM
BMC Nut
Dec 2, 2012 04:40 PM
yeeran
Dec 5, 2011 03:11 AM
TheSeeker
Nov 10, 2010 07:06 PM
mr.xtype
May 11, 2008 09:20 PM
