tranny question
Old Feb 7, 2008 | 09:07 PM
billinohio's Avatar
Default tranny question
so my auto tranny when i wish to manually shift throughtthegears won't go into 2nd. first, is there a seperate shifter part to tranny? i have an aftermarket warranty and it covers
TRANSMISSION
All internal lubricated
parts in:
• Transmission case
• Torque converter
• Bell housing. so do i have to come out of pocket or do i luck out and get it fixed? i need to get my rear passenger door lock actuator replaced and want to roll it all up. dont want to be at the shop and hear, Well Bill it doesn't cover "that particular part". as always, thanks, Bill
Old Feb 8, 2008 | 04:46 AM
FactoryJaguarTech's Avatar
Default RE: tranny question
If it doesnt do anything in second, are you referring to the shifter not lighting up in second?
If this isthe case it is more likely to be your j-gate being bad. Also the range switch in trans.
I would call ext warr co and ask them if they cover the shifter. Also ask if they cover the power door latches for not working. At least that way you'll know whether to take the lube to the dealer with you.
Old Feb 8, 2008 | 08:43 AM
billinohio's Avatar
the door acuators are covered. the shifter won't go into second at all. shift 3rd and 4th. no 2nd.put it in drive and it goes, try to jgate shift and nothing. car runs and shifts automatically fine, just cant go throught the gears "manually". thanks,Bill
Old Feb 8, 2008 | 10:49 AM
billinohio's Avatar
can't physically put the shifter in 2nd gear. car shifts fine in drive. but it won't go into second gear when i switch it overin the jlocation. sorry for confusion.so to recap. car shifts and drives great,except if i try to shift manually through gears on the jgate then there is no 2nd gear. thanks as always,Bill
Old Feb 8, 2008 | 11:43 AM
Dennis's Avatar
ud
Sounds like a j-gate problem or an adjustment
Old Feb 8, 2008 | 05:24 PM
jag_genius's Avatar
sounds like a shifter *** problem or a seized shifter cable..
Old Feb 8, 2008 | 06:26 PM
sounds like j-gate to me
Old Feb 8, 2008 | 07:37 PM
billinohio's Avatar
so what kinda money am i looking at with these problems? just wondering, sounds like all are pretty much adjustment kinda things. thanks, Bill
Old Feb 8, 2008 | 08:01 PM
jag_genius's Avatar
take the right side carpet off... 1 phillips screw and pullthen. in park,disconnect the shifter cable then go thru the j gate.. with cable disconnected... takes 10 min... then if it goes to 2 then it needs a cable .. if it still doesnt then it needs a assembly..
tomsjag
Jun 10, 2023 10:02 AM
Forcedair1
Feb 19, 2020 01:51 PM
picard
Oct 12, 2015 11:56 AM
TreVoRTasmin
Sep 16, 2015 08:14 PM
ratgawd
Sep 16, 2015 04:15 PM
