Trans. fluid check?
Old May 13, 2016 | 05:16 AM
footbrake's Avatar
Default Trans. fluid check?
On my wife's 2004 X-type,3.0, is there a trans fill dipstick to even check the fluid anywhere? Thanks-Russ
Old May 13, 2016 | 05:47 AM
iownme's Avatar
There is not.
The "correct" way to check is to be under the car, with the engine running, then remove a plug from the trans and see if oil spills out... Or something silly like that.
We all here just remove the drain plug, up to 3.5 qts will come out (depending how full it was to start with) then refill using 3.5 qts, this will ensure the correct amount is in there.
Not an ideal way, but thats how we do it.
To flush the trans oil completely we do that process 3 times
Do NOT use regular ATF!
Castrol transmax for import vehicles is the common cheap alternative to jaguars $30 per quart oil, there are a couple others u can use too, not sure what they are
Hope that helps
Old May 13, 2016 | 07:14 AM
DPK's Avatar
DPK
iowme..I've never in all the years here seen it written quite so precise and concise on checking and changing the X's tranny fluid..well done sir!
Old May 13, 2016 | 12:39 PM
footbrake's Avatar
Someone had told me to be careful which plug to unscrew or I could release a clutch drum and the trans would have to come apart to fix it.
Old May 13, 2016 | 01:54 PM
DPK's Avatar
DPK
It is about a 4MM or 6MM allen grub screw..IIRC
But if you just drain out 3.5qts or so and refill with 3.5qts..you'll be just about spot on..As iownme said
Old May 13, 2016 | 06:11 PM
iownme's Avatar
Correct.
Im attaching a pic of the correct drain plug.
It is on the underside of the transmission, facing the road.
I use a 15/16th's socket on it.
I have removed it plenty of times and never changed the crush ring
Old May 13, 2016 | 06:12 PM
iownme's Avatar
Originally Posted by iownme
Correct.
This is looking from the front of the car, driver side, looking up
Old May 13, 2016 | 06:16 PM
iownme's Avatar
In all my years here that is quite the most presise and concise compliment this x owner has ever received ...well done sir!
(and thanks :@)
Old May 20, 2016 | 09:56 PM
swingwing's Avatar
Good info on the drain plug. Am a newbie here - was looking today near the battery box for the fill port. Is is capped by a black rubber plug about 1" in diameter? Looks like moving the battery box slightly might give better access to it.
Old May 21, 2016 | 05:29 AM
iownme's Avatar
Yes.
Much easier to just remove the battery.
I still have not found a funnel that fits, i make my own
Old May 21, 2016 | 07:41 PM
RobinGa's Avatar
Here is what I did - went to Dollar store and bought turkey baster. Took the bulb off the clear plastic tube of baster. I put that narrow end into the fill hole of transmission after taking out rubber plug. Then into the larger opening of baster tube I inserted my standard long transmission fluid funnel. That worked perfect and I refilled Castrol Import fluid using that combination of funnel and tube from turkey baster
Old May 22, 2016 | 09:46 PM
iownme's Avatar
I have so many awesome replies to that, but alas they are all so far beyond politically-correct i'd surely be banned from the intranetz
Old May 24, 2016 | 07:02 AM
swingwing's Avatar
My (new to me) car has 105k miles. After studying the posts in this thread I tackled the ATF change. I removed the battery; doing so makes this service really easy, plus never hurts to give the battery terminals a little attention. The fill plug is the one nearest the water pump pulley. The larger one nearby is a vent plug. First drain gave me exactly 3L of very black thin fluid. I put in 3.5qts of fresh fluid then went for a short drive then returned for the second drain. Fluid drained second time was discolored, but now had some red color to it. This second drain/fill took me all of ten minutes because now I've got the steps down. It's not even necessary to raise the car. The turkey baster/funnel combo (thanks RobinGa) works because the fill port is pretty small. You can bin the rubber bulb as it's not needed. Use a 24mm socket for the drain plug. By the way, you can use the same fluid for the power steering system. I've evacuated the reservoir three or four times now as it's obviously never been touched.
Attached Thumbnails Trans. fluid check?-fill-plug.jpg   Trans. fluid check?-fill-plug1.jpg   Trans. fluid check?-atf-tools.jpg   Trans. fluid check?-atf-fill.jpg
Old May 24, 2016 | 08:00 AM
DPK's Avatar
DPK
Nice job and good info..plus kudos on such a nice clean engine..
Gmorris430
19
Mar 17, 2019 04:05 PM
05S-Stype
22
Oct 9, 2016 03:13 AM
fresno
May 11, 2016 12:34 PM
05S-Stype
May 10, 2016 08:32 AM
Ntimd8
May 8, 2016 06:40 PM
