Transmission Shifting Solenoids Replacement
Old Aug 27, 2022 | 07:57 AM
hak's Avatar
hak
Default Transmission Shifting Solenoids Replacement
2002 X-Type Auto trans 113k Miles. Can someone please post the procedure to replace the shifting solenoids in the X type transmission.
Howard
Old Aug 27, 2022 | 08:23 AM
motorcarman's Avatar
The Jaguar JF506E info can more easily found with search for VW 09A gearbox.
I have replaced all the solenoids in a VW 09A with a kit from a transmission parts seller on the internet. (I forget the seller)
All solenoids as a kit is much less expensive than all purchased from the VW parts dept.
Just replace the parts one-by-one as you go along.
I used a razor blade to hold the threaded studs sticking out of the valve body on some of the solenoids because they can fall back into the mount hole.
File Type: pdf
Old Aug 27, 2022 | 08:58 AM
hak's Avatar
hak
Thank you motorcarman. This is perfect.
Howard
Old Aug 27, 2022 | 11:38 AM
Don't forget to download the .pdf gearbox manual I posted.
Old Aug 27, 2022 | 12:58 PM
hak's Avatar
hak
motorcarman,
Could you please elaborate on how you used the razor blade.
Thanks Howard
Old Aug 27, 2022 | 02:36 PM
The 'studs' holding the solenoids are actually BOLTS (M6x1.25) and the hex is held captive BUT they can be pushed into the valve body when the nut is removed.
To keep this from happening, I hold a razor blade against the threads of the bolt when removing/installing the solenoid AND while installing the nut to secure the solenoid.
A small magnet could possibly pull the bolt back into position IF it gets pushed into the valve body. I don't know how far they can be pushed or whether they can fall inside something if they go too far. (A VW mechanic at the VW dealer told me about this 'trick')
I never let a bolt get away from me so I don't know the consequences.
Old Aug 27, 2022 | 05:31 PM
hak's Avatar
hak
motorcarman.
Great advice and I did forget the download the file, so I just downloaded it.
Thanks Howard
Old Sep 3, 2022 | 10:15 AM
hak's Avatar
hak
mototcarman,
I purchased the solenoids you recommended and have some questions that I need your help with.
One of the bolts holding the pan at the top is next to what appears to be a vent and I cannot get a wrench on it. Can the vent cap be removed? if so how?
Did you replace the trans filter? Is the filter accessible after the pan is removed?
Do you know the torque spec for the pan bolts?
Any info/procedure you have on removing and replacing the pan and filter would be greatly appreciated.
Thank you
Howard
Old Sep 3, 2022 | 10:55 AM
Been a long time since I replaced solenoids in a JATCO gearbox.
The cap needs to be removed for bolt access.
The fine mesh screen filter is NOT serviceable. It is buried DEEP in the gearbox.
I just use a 1/4 drive ratchet for torquing the M6 bolts so I have no idea what the actual spec is.
I have been working on Jaguars for almost 50 years and after a few decades, you just get a 'feel' for small bolts so they don't snap and yet become tight enough to seal the flange.
There is probably a universal torque spec for M6 bolts like there is a universal spec for SAE bolts.
https://www.engineeringtoolbox.com/m...ue-d_2054.html
Old Sep 3, 2022 | 07:04 PM
Dell Gailey's Avatar
If you ever get froggy. As motorcar man said it's internal.
Old Sep 4, 2022 | 07:06 AM
hak's Avatar
hak
Thank you for the bolt torque specs.
Old Sep 4, 2022 | 05:00 PM
hak's Avatar
hak
motorcarman,
Because of all your help, I now have 8 solenoids replaced. The last one I am trying to replace is N93. To remove this one there is a wiring connector above it that must be removed. I have pulled on it but could not disconnect it. I cannot see any locking mechanism. Do you remember how you removed/disconnected this connector?
Thanks,
Howard
Old Sep 4, 2022 | 05:40 PM
hak's Avatar
hak
motorcarman
the solenoid is circled in green
Howard
The green is the solenoid.
2jag
Jan 22, 2013 11:21 AM
heima
Nov 15, 2012 10:40 PM
domer94
Apr 3, 2012 07:59 PM
domer94
Feb 20, 2012 07:29 PM
Audie1966
Mar 3, 2011 05:03 PM
